Thread: VW VENTO CUT OUT PROBLEMS
Page 3 of 3 FirstFirst 123
Results 21 to 30 of 30
  1. Re: VW VENTO CUT OUT PROBLEMS
    #21
    ive just baught a fuel pump for my problem listed above. ill let people know if its resolved
  2. Re: VW VENTO CUT OUT PROBLEMS
    #22
    Nov 2008
    I had the same problem with my 1.8CL vento, It turned out to be the matrix heater, hope that helps CP.
  3. Re: VW VENTO CUT OUT PROBLEMS
    #23
    he matrix used to make the car cut out as we've described? hmm not heard of this problem. do u know how it caused it? let hope its the fuel pump as im waiting for my new one to arrive.
  4. Re: VW VENTO CUT OUT PROBLEMS
    #24
    ok well the fuel pump arrived. i did 1 last test before swapping it, and when i went out tot he car it wouldnt start at all, i had my dad in the boot to here if the pump was priming whist i turned the ignition and there was nothing, so i swapped the fuel pump relay(although that was the first thing i did after reading this thread) with the one from my mk2 golf and it instantly started working. done 100 miles odd around town with no probs so far. so a tip to anyone having simlar issues is try 2 relays
  5. Post Re: VW VENTO CUT OUT PROBLEMS
    #25
    Mar 2006
    county durham (north east uk)
    father in law had similar probs with his vento 2.0 GL 8v (2E engine)
    turned out to be the ignition coil (breaking down when hot)
    and sometimes the car would not start at all & that was the crank sensor,
    but as we all know the crank sensor on the 2.0 8v is incorporated into the
    distributor so we had to search the whole of the north east for a replacement
    after that though the vento ran perfect,
  6. Unhappy Re: VW VENTO CUT OUT PROBLEMS
    #26
    Bournemouth
    Quote Originally Posted by 91oldskoolsoldi View Post
    Just Brought The New Ecu Power Relay..........
    Guess What It Dosent't Work....... F~@ck F~@ck F~@ck....
    Had To Get The R.a.c Out....first Of All The Mech. Said It Was The Ignition Plug....wrong..
    Then Said The Dizzy Is Giving Out A Strange Spark, As In It Was Cutting Out Then Back In.. He Suggested Getting The Thing Tested....
    I Think It May Be My Fuel Pump,as The Power Stays On Ie The Lights And Dials,only The Engine Cuts And The Fuel Pump Relay Clicks Like Mad... Or...
    Could It Be The Crank Speed Sensor....... !!!!
    Any One Have Any More Good Advice
    I've been having the same problem with my A6 2.5 tdi V6 SE. It just cuts out as your driving along normally. It usually restarts straight away, but it is a MASSIVE pain in the @rse.
    Took it to my local deisel specialist. He plugged it in, read the fault code, turns out to be a faulty engine speed sensor in the injection pump. He even read the fault code from the injection pump itself just confirm the fault, it was correct.
    So, its going in tomorrow, gonna cost about £600 to get it sorted........
    GUTTED........
  7. Re: VW VENTO CUT OUT PROBLEMS
    #27
    May 2009
    Southend on sea United Kingdom
    My Vento TDI had the same cut out problems. after replacing the 109 relay, all CUT OUT problems where something of the past.!!
    THANKS
    Duan Vogel
  8. Re: VW VENTO CUT OUT PROBLEMS
    #28
    Jan 2021
    România
    Hello guys! I have a problem with my Vento, when I start the car when the engine is cold, it works perfectly, but if the motor is hot and I turn it off, when I start it again, the car goes max to 110-120km/h. It's like it does not get enough airflow. I put the car on a tester and it said that the debitmetter is fault, but I've changed the debitmetter and same situation.
    Do you have an idea on what the problem could be? Thank you very much!
  9. Re: VW VENTO CUT OUT PROBLEMS
    #29
    Dec 2006
    Thanks it was the relay switch in the end cost £50 a lot but it worked fine after that the garage told me it was common on Ventos and golf mk4s ....
  10. Re: VW VENTO CUT OUT PROBLEMS
    #30
    1840 Post(s)
    Quote Originally Posted by duanvogel View Post
    You will get a much better response if you start your own thread, tacking onto 12 year old threads means people my miss you.
  1. tuning a tdi 90 vento
    By vwnige in forum Vento - 1994 - 1998
    Last Post: 06-10-2007, 09:03 PM
  2. vw vento clutch problems
    By radpm2 in forum Vento - 1994 - 1998
    Last Post: 31-05-2007, 03:38 PM
  3. best brand of oil for a vento tdi
    Last Post: 04-05-2007, 12:04 PM
  4. vibrating vento tdi
    Last Post: 04-05-2007, 01:06 AM
  5. VENTO Brakes
    By gerryt in forum Vento - 1994 - 1998
    Last Post: 29-01-2005, 09:08 PM
