Thread: Sump plug location..
  1. Sump plug location..
    Mar 2008
    Bucks
    Im about to do an oil & filter change on my '99 1.9TDi but I cant face going out in the rain at the moment to remove the engine tray ...
    Sat here with nowt to do so I thought I may as well pick someones brains( read;save some time..) & ask whether the sump/drain plug is located towards the front or rear of the beam? Might I get away with removng only one half of the protective tray?
  2. Re: Sump plug location..
    Dec 2006
    I'd remove the tray completely, it'll only get in your way otherwise and if you just unclip half of it, you risk snapping the plastic clips that secure it in place. I just bought 4 of these from VW for £12, so don't cut corners. The sump plug is located on the passenger side of the sump (right hand side if looking at the car head on) if that makes sense. I did an oil & filter change last week and due to the sump plug location, I parked the car with the driver's side wheels on the kerb and the passenger side on the ground, hence pouring the oil straight out of the sump, then rolled it back onto level ground to refill.
  1. Oil Drain Plug (or Sump) Removal Problem
    By Chromate in forum Golf MK3 - 1993 - 1999
    Last Post: 05-03-2008, 12:41 AM
  2. Glow plug relay location
    By Goulders in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 21-02-2008, 01:44 PM
  3. Golf Gt tdi (140) Sump plug torque setting.
    By richard_vw in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 25-08-2007, 10:54 AM
  4. Audi A4 - Siezed sump plug
    By A4Chris in forum Archive posts
    Last Post: 10-05-2007, 10:37 AM
  5. How do i find the sump plug 2004 Golf 2.0 TDI
    By daveaustin in forum Archive posts
    Last Post: 18-04-2007, 12:58 AM
