Thread: ABS water pump -How much play is too much play?
  1. Unhappy ABS water pump -How much play is too much play?
    Hi Folks,
    My 1.8GL is making an intermittant knocking/tapping noise that appears to be coming from the water pump.
    If I slacken the alternator bolts and push down on the alternator to loosen the ribbed belt while the engine is running, the noise changes/goes away.
    If I push down on the alternator (while the engine is stopped!) and grab hold of the pulley on the water pump as best as I can, I can detect a small amount of play. Would you say that this means that the pump is knackered? I'm kind of thinking that if I can detect play then there's more than is obvious.
    It's raining and I don't fancy 3 or 4 hours spent changing the pump only to find that it aint broke.
    Cheers for any help or guidance
  2. Re: ABS water pump -How much play is too much play?
    Looks like I misdiagnosed the problem
    Changed the water pump only to be greeted by the same knock at start up.
    Decided to triple check the crank pulley bolt and found it to be, lets say, a little on the loose side.
    Quick tweak with a socket on a 4ft bar and all seems to be well,touch wood.
    Oh well, you live and learn (sometimes...)
  1. Bora steering play
    By Piston-skint in forum Bora - 1998 - 2005
    Last Post: 04-10-2008, 12:02 PM
  2. how much play should there be in the flywheel
    By justin@justinwa in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 02-03-2008, 11:54 PM
  3. arb has play in bush/link
    By plees99 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 26-02-2008, 09:23 PM
  4. Plug and play chipping
    By daniel408 in forum Golf MK5 - 2004 - 2009
    Last Post: 11-02-2008, 09:23 AM
  5. RCD 500 -Does it play MP3 cd's
    By rodpat in forum Passat - Archive Topics
    Last Post: 16-03-2007, 10:10 AM
