Thread: Need to change fuel filter on T5
  1. Need to change fuel filter on T5
    Hi I have a 2004 T5 transporter TDI & need to replace the diesel fuel filter.
    My question is,
    Will turning the engine on the starter self bleed the air out of the system or is there a procedure to bleed the engine.
    Any help will be Great thanks---- Graham.
  2. Re: Need to change fuel filter on T5
    Mount Barker, South Australia
    Quote Originally Posted by SmithG View Post
    My question is,
    Have a look at the Fuel Filter Change Procedure on my Website.
    I think you may have to turn the "ignition" key on and off a few times.
    I presume you have a fuel pump in the fuel tank.
  3. Re: Need to change fuel filter on T5
    Hello.
    Change the filter, start it up. Job done.
    As above, primer pump in tank tank fills the new filter. It might run a bit rough for a couple of seconds but it will soon clear.
  1. Fuel filter change
    By NICK H in forum Octavia
    Last Post: 14-05-2010, 01:03 PM
  2. tdi Air purge after fuel filter change?
    By Timk in forum 80 - 90
    Last Post: 28-03-2008, 01:42 PM
  3. New fuel filter does not change a thing
    By energize in forum Passat - B5 Forum - 1997 -2005
    Last Post: 22-03-2008, 05:48 PM
  4. Fuel Filter change caused problems: HELP!
    By andysuth in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 07-09-2007, 09:04 PM
  5. How do i change the fuel filter 2004 Golf 2.0 TDI
    By daveaustin in forum Archive posts
    Last Post: 17-04-2007, 11:36 PM
