Thread: Clearing ABS Faults using Vag-com Golf mk3 gti 16v
Page 1 of 4 123 ... LastLast
Results 1 to 10 of 37
  1. Thumbs up Clearing ABS Faults using Vag-com Golf mk3 gti 16v
    Hi i have VAG-COM version 311 full version and the lead (USB to Serial) which works a treat, i was recently able to diagnose a fault with the engine speed sensor with it.
    However it also picked up some errors with regards to the ABS system, i am pretty sure they are old codes that need to be cleared, so i want to clear them and run the car for a few days and then plug the lead back in and rescan for codes. My problem is that the codes will not clear using this software, i hit the clear codes button and it does nothing.
    Does anyone know how i can get them to clear?
    Thanks in advance for you help. Great forum this by the way!
  2. Re: Clearing ABS Faults using Vag-com Golf mk3 gti 16v
    7 Post(s)
    On the older versions, I think you need to log into the particular module and clear the faults from there. The new newer versions allow you to clear all faults from the auto scan screen.
  3. Re: Clearing ABS Faults using Vag-com Golf mk3 gti 16v
    Yeah ive tried doing it from the individual module screen but its still the same, just kinda blinks but does not clear the codes. Same with the clear all DTC's button.
    Do you think that i can perform this function on a new version of the software (shareware) with my current lead?
  4. Re: Clearing ABS Faults using Vag-com Golf mk3 gti 16v
    7 Post(s)
    Quote Originally Posted by Flex View Post
    No.
    I now think the reason you cannot clear the faults is that they are still there?
    What codes are you getting ?
  5. Re: Clearing ABS Faults using Vag-com Golf mk3 gti 16v
    Here ya go:
    VAG-COM Version: Release 311.2-N
    Chassis Type: 1H - VW G/J/V Mk3
    Scan: 01,02,03,08,15,25,56
    Address 01 -------------------------------------------------------
    Controller: 037 906 024 BE
    Component: DIGIFANT 3.2 1953
    No fault code found.
    Address 03 -------------------------------------------------------
    Controller: 3A0 907 379 E
    Component: ABS/EDS ITTAE 20 GI V00
    Coding: 03704
    Shop #: WSC 00000
    2 Faults Found:
    01276 - ABS Hydraulic Pump (V64)
    16-00 - Signal Outside Specifications
    00287 - ABS Wheel Speed Sensor: Rear Right (G44)
    35-00 - -
    Skipping Address 15-Airbags
    Address 25 -------------------------------------------------------
    Controller: 1H0 953 257 B
    Component: IMMO VWZ3Z0T2358765 V00
    Coding: 09600
    Shop #: WSC 00000
  6. Re: Clearing ABS Faults using Vag-com Golf mk3 gti 16v
    1840 Post(s)
    The reason they will not clear is they are current faults and they won't clear until you fix them. Unfortunately a rear right sensor code normally means a faulty ECU as does the other code. Disconnect the ABS sensors under the back seat and swap the plugs over. Read and clear the codes again and see if the rear sensor fault changes sides, if it does you have a faulty sensor on the right and if it doesn’t clear, the ABS ECU is faulty.
  7. Re: Clearing ABS Faults using Vag-com Golf mk3 gti 16v
    Cool thanks a lot, i will try that! One thing though, if there really was errors wouldnt the dash abs light not be on constantly to disable the system? The abs light on the dash lights up when the ignition turns on for a couple of secs and then goes off.
  8. Re: Clearing ABS Faults using Vag-com Golf mk3 gti 16v
    1840 Post(s)
    That is odd but then again, the ECU is probably faulty. Try generating another code by disconnecting the left sensor under the back seat and see if that will clear.
  9. Re: Clearing ABS Faults using Vag-com Golf mk3 gti 16v
    Right done a quick swap over of the sensor leads as suggested and the fault seems to follow the sensor, as you can see its now reporting the left. When i cleared the codes again the error for the right one disappeared.
    Control Module Part Number: 3A0 907 379 E
    Component and/or Version: ABS/EDS ITTAE 20 GI V00
    Software Coding: 03704
    Work Shop Code: WSC 00000
    2 Faults Found:
    00290 - ABS Wheel Speed Sensor: Rear Left (G46)
    35-00 - -
    If i check / replace the sensor do u think it will clear the other code, would "signal outside specification" be because of a faulty wheel sensor?
  10. Re: Clearing ABS Faults using Vag-com Golf mk3 gti 16v
    1840 Post(s)
    Try running the pump in output tests, it still points to a faulty ECU and possibly pump as well, we change a lot of these units.
  1. new faults on vag-com help please
    By zorgman in forum Touran - Sharan - Caravelle
    Last Post: 10-02-2008, 04:54 PM
  2. Eos faults
    By hitachizx in forum Eos
    Last Post: 11-01-2008, 11:49 PM
  3. Golf mk4 tdi odd electric faults
    By lightbulb in forum Archive posts
    Last Post: 05-01-2008, 11:51 PM
  4. A3 1.8T - faults to look for
    By Graham in forum Audi A3 - Archive Topics
    Last Post: 01-08-2006, 11:12 PM
  5. VAG-COM Faults
    By anoak in forum Passat - Archive Topics
    Last Post: 14-07-2006, 09:25 PM
