Thread: Help with fault codes...
  1. Help with fault codes...
    Mar 2008
    My cheapy shareware version of vag com wont tell me what these are:
    17953
    16502
    16515
    17916
    Also, when I go to clear them, im told I need a professional cable to do it. I had enough grief getting vag com to work on vista.
    Can anyone let me know what those codes are? Thanks
    Rich
  2. Re: Help with fault codes...
    Apr 2007
    Lancashire
    17953 = Throttle butterfly valve control, malfunctioning.
    16502 = Coolant temp. Sensor (G62): Signal too High.
    16515 = Oxygen (Lambda) sensor Bank-1 Sensor-1, Low voltage.
    17916 = Idle Sys.Learned VALUE Upper limit Attained.
    I use this fault code list a lot, it will need translating, but is quite complete.
    http://www.gerritspeek.nl/vag-com_foutcodeslijst.html
  1. Fault Codes
    By jayde17 in forum Polo - Derby - Lupo - Fox
    Last Post: 07-03-2008, 09:47 PM
  2. any one had these fault codes??
    By Adamtdi in forum Passat - B5 Forum - 1997 -2005
    Last Post: 23-02-2008, 12:27 AM
  3. fault codes
    By zoebunny in forum Archive posts
    Last Post: 19-10-2007, 09:49 PM
  4. Vag Com Fault Codes
    By bobdobelina in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 30-08-2007, 12:50 PM
  5. Fault codes
    By andyd118 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 17-05-2007, 10:27 PM
