Thread: Audi Audio Questions
  1. Question Audi Audio Questions
    Dec 2006
    Hi, I am a new member to this site but I in need of some HELP!!, this question has probably been asked before but being a simpleton I'm hoping somebody can assist me.
    I have a 2001 A4 1.8se saloon, last of the original shape B5(?) models, fitted with a Concert 1 radio which has died with the volumne problem. I would like to keep the car original as possible, so is it possible to fit a Concert 2 radio with regards to wiring/physical size/ work with the DIS display/ dash cutout slot etc???
    Also I have seen Concert 2 radios with different part codes, and with buttons that are retractable or fixed, does the different part codes refer to the differing DIN sizing to the units/ connections etc??
    I would be very gratefull for any assistance.
    Regards, Jason
    Jason
    Dec 2006
    Hi, I am trying the same thing concert II into a Concert I. Not all are the same size. Some sizes are given below also a good site is:
    http://www.ibiblio.org/tkan/audi/radios/
    One issue you will get is the older Audis do not have the CAN BUS which means a Concert II will not light up the buttons and does not power from the ignition switch. As a result it will power off after one hour.
    8E 0035 86D 8E0035186J 235mm x 65mm silver strip
    8Z 0057 186GX
    8B0 035 186 Q 220mm across the top and 58mm bose system
    There is a fix for the buttons illumination on the Audi-Sport.net forum, but requires opening up soldering and a wire out of the radio
    Cheers hope this helps.
    Dec 2006
    Hi Rmullins, many thanks for the info, good to know I am not the only one with this problem. I am off to borrow the Concert 2 unit from my dads A4 advant, now I've purchase some removal keys.
    I'll let you know how I get on, many thanks.
    Jason
    Dec 2006
    Wiltshire
    You will have a lot of difficulty getting the Concert II to work properly where a Concert 1 has been fitted.
    The Mk II cd units units, rely on a CAN bus signal to turn on / off with the ignition that is not present in the older cars.
    The size issue will also present a problem as they are different widths and heights fittings between the old and new units.
    The volume control problem can be fixed, but requires replacement of the main microprocessor in the Concert I. My firm specialise in these repairs if you want further details please let me know.
  5. Re: Audi Audio Questions
    Henfield West Sussex
    Can you tell me which firm will mend my volume control on my Concert 1 radio.
    Thank you.
  6. Re: Audi Audio Questions
    Nov 2008
    Hello,
    "There is a fix for the buttons illumination on the Audi-Sport.net forum, but requires opening up soldering and a wire out of the radio"
    Where is this fix??Can`t find it :P
  7. Re: Audi Audio Questions
    Apr 2007
    Evening Folks,
    Have noticed there's usually a few 2nd hand Concert units kicking around on ebay and in the classifieds on some of the UK Audi forums. Maybe worth a look?
    Good luck resolving the issue!
    J
    1999 Audi A4 1.8T Quattro Sport Saloon (180bhp)
  1. Audio upgrade?
    By AUDICAB99 in forum 80 - 90
    Last Post: 29-05-2007, 11:15 PM
  2. audi 100 2.6 v6 avant questions
    By v6chris in forum 100 - 200 - Turbo - 100 S4
    Last Post: 28-04-2007, 12:40 AM
  3. In car audio question
    By richjthorpe in forum Audi A4 - Archive Topics
    Last Post: 23-01-2007, 10:08 AM
  4. A4 Audio problem?
    By DaveG in forum Archive posts
    Last Post: 08-11-2006, 10:46 AM
  5. Replies: 0
    Last Post: 07-09-2005, 08:31 PM
