Thread: fault codes read + 1 found.
Results 1 to 10 of 12
  1. Post fault codes read + 1 found.
    essex
    I have had my car fault code read today as is running very badly and it came up with the code p0301, which i was told was a misfire in cylinder 1. It defo seems like a misfire but how can a diesel misfire it doesnt have any spark plugs!! Which cylinder is no. 1 cylinder. i have a 1.9tdi quattro engine.
  2. Re: fault codes read + 1 found.
    Bournemouth
    here is a link to ross tech's wiki page for your fault code
    http://wiki.ross-tech.com/index.php/16685/P0301/000769
    dunno if it will help, but it will give you other areas to look at...
  3. Re: fault codes read + 1 found.
    essex
    The car is with the garage now, they seem to think its the injector causing the problem. Thet say the passat has the same problem with its injectors. What problem??
  4. Re: fault codes read + 1 found.
    7 Post(s)
    I'd get a second opinion.
    The wiring looms to the injectors do break down. I hope they don't try and flog you an injector plus fitting for £500 or whatever when all it could need is a new loom.
  5. Re: fault codes read + 1 found.
    essex
    Me too. its the first time ive used them, so i just hope they are going to try to fleece me. I could really do without big bills but then i guess so can everyone else.
  6. Re: fault codes read + 1 found.
    Mauritius
    I had the same problem in January - Misfiring. The car shudders when idle and engine running. They had to change an injector
    For the last 2 weeks, my car had difficulty starting in the morning. Then Ion saturday i noticed the shuddering again when car is idle in traffic and car produced a lot of smoke. The scan at the Audi garage showed a misfire in Cylinder 3. They said it could be a faulty injector again (A4 1.9TDI has 4 injectors)...
  7. Re: fault codes read + 1 found.
    7 Post(s)
    Gents,
    As above, I'd suspect the loom first, especially when you have one injector fixed then mysteriously another fails. Note that the whole loom needs to be removed each time work is done to remove each and any injector.
  8. Re: fault codes read + 1 found.
    essex
    still waiting for mine to come back, they dont seem to be in a hurry, but at least i got to borrow a vehicle to run around in... a suzuki alto lol.
  9. Re: fault codes read + 1 found.
    Lincoln, NE, USA
    what ur odo reading? could be glow plugs.. but that wouldn't cause a misfire, injector sounds more reasonable
  10. Re: fault codes read + 1 found.
    Mauritius
    Quote Originally Posted by tyberwan View Post
    Diagnostic from Audi garage today - A faulty injector again!
    If you say it may be the loom wiring etc, how will we ever know that if we are not mechanics? How can we also check that the failed injector they give you back in return is still working, i heard it's electronic. Are there repair shops for electronic injectors?
  1. Fault Codes
    By jayde17 in forum Polo - Derby - Lupo - Fox
    Last Post: 07-03-2008, 09:47 PM
  2. I just had the codes read...need some input lads....!!
    By Bodferret in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 16-02-2008, 12:07 AM
  3. Fault found after vag-com scan. Help??
    By ickleric in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 01-02-2008, 11:46 PM
  4. Can anyone help with fault codes please
    By kaygolf in forum Archive posts
    Last Post: 02-11-2007, 05:44 PM
  5. vag com fault codes
    By Dozz in forum Audi A4 - Archive Topics
    Last Post: 10-06-2007, 12:45 AM
