Thread: Alarm issue!
  1. Alarm issue!
    Mar 2008
    Hi guys,
    Bought a second hand Passat 1.8T Sport a few days ago, and just sorting out a few problems...
    When i got the car the battery was dead (which i knew about) so i replaced it with a brand spanker, all sorted. I have had no problems with the alarm/central locking etc since battery replacement.
    Another issue i was sorting was that the standard fit radio wasn't working, got myself a set of radio keys and took the unit out to find that the 10A fuse at the rear was blown... replaced this, radio synched with car all sorted me thinks...
    Now whenever i lock the car (and hence activate the alarm) it goes off at a random time from 1 min after i set it to anything up to 15mins :-s
    Any ideas? Have i disturbed something when i changed the fuse in the head unit?
    Many thanks in advance,
    Matt
  2. Re: Alarm issue!
    Jun 2006
    UK, Mids
    Possible the bonnet switch/microswitch, try searching on here, I have read it a few times, but never had the problem myslef, so never looked into it.
    Audi A8 - 2015 - 3.0TDI
  3. Re: Alarm issue!
    If you press the remote once to lock the car do you indicators flash? And if you press the lock button on the remote a second time to disarm the alarm does it still go off?
    Another possibility and a common source of gremlins for the electrics and the alarm, is the seal on the pollen filter leaking. This leaks water on to the wiring loom behind the trim left hand side of front passenger foot well and the convenience control unit which lives under the carpet in the same location. Check to see if your carpet is damp/wet
    Do a search for "alarm" and a search for "water" and you will see lots of threads on the subject.
    Read the fun I had https://www.vwaudiforum.co.uk/forum/s...ad.php?t=21101
    Note my famous last words "The battery tray is dry"
  1. ABS Issue
    By cronemeister in forum Bora - 1998 - 2005
    Last Post: 03-03-2008, 09:15 AM
  2. CVJ issue?
    By Rutland Gizz in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 06-12-2007, 04:14 PM
  3. Rear window / Alarm issue
    By bora(ing) nick in forum Chat - Anything with wheels
    Last Post: 25-10-2007, 01:07 PM
  4. Air Con Issue
    By Audi Eire in forum Audi A3 - Archive Topics
    Last Post: 13-06-2007, 05:19 PM
  5. yet another issue
    By ktscarlet in forum Chat - Anything with wheels
    Last Post: 30-10-2006, 02:58 PM
