Thread: egr valve on tdi passat
  1. egr valve on tdi passat
    Dec 2007
    wigan
    people mention cleaning the egr valve on a volkswagen as to sometimes improve fuel usage... where is the egr and how shud it be cleaned...?? a picture of its location would be great as well unless it will really jump up and smack me in the face...lol thank's
  2. Re: egr valve on tdi passat
    Mar 2006
    Hello
    I would be intersted in finding this too.
    Does anyone have an idea, pictures would be great.
    Shab
  3. Re: egr valve on tdi passat
    Aug 2007
    It's a shiny cylinder with a vacuum hose exiting from the centre, mounted on the exhaust manifold in the engine bay.
    I've no idea how you clean it, caustic soda???
    Chris
  4. Re: egr valve on tdi passat
    7 Post(s)
    You need to remove it from the car to clean it.
    Once off, use carb cleaner or thinners and then rinse everything with brake cleaner.
    Also make sure you have a new 'o' ring and manifold gasket just in case you damage the existing ones.
    As for the location of it, you should get a Haynes manual as a minimum if you are considering doing any work on your car.
  5. Re: egr valve on tdi passat
    Mar 2008
    Here it is
    https://www.vwaudiforum.co.uk/forum/a...0&d=1179680191
    and mine removed today for this exact job
    all that it involves is to remove the engine cover plate and the air intake clap then the 3 hex bolts holding it to the manifold and the lower 12mm nuts to the exhaust.
  6. Re: egr valve on tdi passat
    Sep 2007
    My egr valve is forever covered in oil is this right to have lots of oil round there???
    Andy
  7. Re: egr valve on tdi passat
    best take off all the pipes down to the intercooler and clean em out andy . mine had oil inside , but not to the extent of being literally covered as you say . THE worst one was the intercooler on the passenger side , it has a recess and was about an inch deep in black engine oil .
  1. Replies: 9
    Last Post: 19-01-2008, 07:40 PM
  2. Dump valve for passat 1.9 se tdi
    By loci1969 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 19-11-2007, 12:04 AM
  3. Dump valve for passat 1.9 se tdi
    By loci1969 in forum Chat - Anything with wheels
    Last Post: 17-11-2007, 07:52 PM
  4. n75-h valve
    By lee2u in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 05-08-2007, 06:39 PM
  5. replacing atmospheric dump valve with re-circ dump valve
    By vwgolfturbo in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 04-02-2007, 10:27 PM
