Thread: 6N Polo cooling problem!!
  1. 6N Polo cooling problem!!
    May 2007
    South West
    Hi there people,
    I have a VW Polo 1997 1.4CL, and I have recently found that the engine has not been running at a good temperature, it doesn't even move over the 70degrees mark. The weird thing is the heaters work very quickly from first start.
    Could this be a thermostat stuck fully open allowing the water to run around the whole system constantly?
    Could it be a blocked rad?
    And advice welcome
    Dan
  2. Re: 6N Polo cooling problem!!
    Try letting it tick over till the fan (hopefully) cuts in, still reading cool? then its probably a duff gauge or sender. If it reads around 100 the the gauge is fine, so try driving and see if it drops off to 70 again, then the thermostat is leaking or opening early but if you are getting good heat in the car its more likely the sender, i'd say.
  3. Re: 6N Polo cooling problem!!
    May 2007
    South West
    Quote Originally Posted by mattijw View Post
    I changed my thermostat, its perfect now, i completely drained the coolant too and started with fresh!
    i didnt think it would be the thermo either cause i was getting very good heat inside the car, i found out that the thermo was constantly open!
    Thanks for the advice
    dan.
  1. Polo Cooling system
    By nigell in forum Polo - Derby - Lupo - Fox
    Last Post: 27-03-2008, 09:35 PM
  2. cooling fan problem
    By afox101 in forum Golf MK5 - 2004 - 2009
    Last Post: 20-03-2008, 11:59 PM
  3. 1998 Polo 1.4 16v Heating/Cooling issues
    By stevepud in forum Polo - Derby - Lupo - Fox
    Last Post: 05-01-2008, 04:14 PM
  4. A3 Cooling Fan Problem
    By MOTOW in forum Audi A3 - Archive Topics
    Last Post: 10-10-2007, 09:05 PM
  5. A6 Cooling Problem
    By trainspotter in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 28-02-2007, 08:55 PM
