Thread: Constant Pressure in Expansion Tank
  1. Constant Pressure in Expansion Tank
    Jul 2007
    Is this normal? Even when my engine has been standing overnight there is still a lot of pressure in the expansion tank. I have to slowly unscrew the cap but this still results in a big release of pressure and coolant spraying out.
    Is this common?
  2. Re: Constant Pressure in Expansion Tank
    Jul 2007
    Help anyone?
  3. Re: Constant Pressure in Expansion Tank
    Even when my engine has been standing overnight there is still a lot of pressure in the expansion tank.(This does not sound normal) with that amount of pressure overnight,is it a petrol or diesel
  4. Re: Constant Pressure in Expansion Tank
    Jul 2007
    Its a 1.8 petrol
  5. Re: Constant Pressure in Expansion Tank
    Hi I would try replacing the cap on the expansion tank.If you suspect the head gasket there is a tool which you can use to see if there is exhaust gas in the coolant.A leaking head gasket will also build up pressure in the coolant system,although when that is the case you can not keep water in the tank because of the high pressure.A leaking head gasket can be the cause and it does not always show signs of water in the oil
  6. Re: Constant Pressure in Expansion Tank
    Jul 2007
    Thanks for the reply
    I do high mileage in it and on average top up the coolant every two weeks,there is no oil in the coolant or coolant in the oil.
    It does use a bit of oil though.
    What could be wrong with the cap?
  1. Engine Cutting Out, Tank Pressure Valve N80
    By Raitis in forum Passat - B5 Forum - 1997 -2005
    Last Post: 11-03-2008, 09:13 PM
  2. Oil in Expansion Tank - PD150
    By KashBash in forum Golf MK4 - 1999 - 2004
    Last Post: 18-02-2008, 06:42 PM
  3. Expansion Tank 1.8 20v.2000 Passat
    By paul vivian in forum Passat - B5 Forum - 1997 -2005
    Last Post: 20-01-2008, 09:43 PM
  4. MFD constant pinging
    By vallers in forum Golf MK5 - 2004 - 2009
    Last Post: 30-12-2007, 06:42 PM
  5. coolant expansion tank
    By remember1t in forum Golf MK2 - 1984 - 1992
    Last Post: 09-10-2007, 09:30 PM
