Thread: avant rear water jet
Results 1 to 9 of 9
  1. avant rear water jet
    Dec 2007
    the rear water jet on my 2002 avant wont work i can hear pump and wiper works no blockage does the rear run off the same bottle as the front ?
  2. Re: avant rear water jet
    Dec 2007
    Aberdeenshire, Scotland.
    If I were you I would immediately check your spare wheel well for screen wash leakage.
    My 03 Avant had this problem, and when I looked in the wheel well it was full of screen wash! Took me ages to bail it out and dry it.
    Turned out the pipe had come off the end of the nozzle and screen wash was p***ing into the boot every time I tried the washer!
    Got my local independent garage to fix it for about £30.
    Go check it now!
  3. Re: avant rear water jet
    Dec 2007
    just checked boot its bone dry
  4. Re: avant rear water jet
    Dec 2007
    Quote Originally Posted by bez101 View Post
    Glad to hear it's dry- it uses the same bottle front and back.
    The only thing I can think of is a blocked washer jet. Is your front washer ok?
  5. Re: avant rear water jet
    Dec 2007
    Just a quick thought- in addition to checking the boot, did you also check under the spare wheel? My boot looked dry, but it was only on checking the spare wheel well that I found all the water!
  6. Re: avant rear water jet
    Dec 2007
    yeah spare wheel well dry front work fine washer pump makes noise and no blockage im goin to put an air line on it and blow it through see if that cures it
  7. Re: avant rear water jet
    Aug 2007
    Norwich
    You can also try cleaning out the nozzles on the actual wiper with a pin. They can get blocked up with gunk. If you do have to take of the trim on the boot lid there is 4 bolts, 2 in the warning triangle stowage and 2 near the outer edge, all on the under side. Then there is just clips holding the trim on. These clips will be very stiff and a pain to push back in. But you should be able to lift trim enough to have a look with out popping the clips out.
  8. Re: avant rear water jet
    Dec 2007
    thats the 1st thing i did
  9. Re: avant rear water jet
    Lancashire
    Mine got blocked up so I just used a needle to clear it out. It works off the reservoir in the engine bay.
    54 Audi A4 Avant 1.9TDi 130 SE 6-speed, RNS-E, rear parking sensors, bluetooth
  1. Audi A6 Avant - Water in footwell problem
    By gunner in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 10-05-2013, 11:30 AM
  2. Water in Boot and Rear Fog(s)
    By chrisvrscrx in forum Passat - B5 Forum - 1997 -2005
    Last Post: 09-03-2008, 06:26 PM
  3. A4 Avant Water Inside Tailgate
    By pologt in forum Audi A4 - Archive Topics
    Last Post: 20-11-2007, 08:47 PM
  4. A4 Avant water leak
    By RodgerW in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 10-09-2007, 08:59 PM
  5. Water in rear footwell
    By duncan171 in forum 80 - 90
    Last Post: 12-07-2007, 11:59 AM
