Thread: turbo vacuum pipe layout.....
Page 1 of 3 123 LastLast
Results 1 to 10 of 24
  1. turbo vacuum pipe layout.....
    Oct 2006
    I've just bought myself an A4 Avant 1996 110 BHP.
    Been looking under the bonnet & there is a vacuum pipe that is not connected to anything - i've tried blanking it off but it does not seem to make a difference
    The car seems to have no turbo boost, but before going down the MAF route I would like to ensure that all the vacuum pipes are routed correctly & replace any older/perished lookin ones.
    So does anyone have a schematic of the vac pipe layour - what should be connected to what - I'm pretty sure that there should not be an open end on any of these vac pipes - but there is at the moment.......
    help me give my new toy a higher powered lease of life so I can start enjoying it.......
  2. Re: turbo vacuum pipe layout.....
    Hi Let me have your engine code and your e.mail address and i will send you a diagram
  3. Re: turbo vacuum pipe layout.....
    Apr 2007
    Lancashire
    110 vac control layout:
    Turbo
    (one on right for 110)
    The most obvious tube is the N75 to turbo vac actuator (ontop of the turbo).
    EGR
  4. Re: turbo vacuum pipe layout.....
    Oct 2006
    mine is the 110 BHP - would that be the AFN engine ?
    Just had the EGR valve off cleaned it, took it for a blast down the by-pass, still no different, but the smoke that was blowing out from the back has now stopped - well reduced vastly !
  5. Re: turbo vacuum pipe layout.....
    Apr 2007
    Lancashire
    Where abouts is the tube located?
    Can you post a picture of the area?
  6. Re: turbo vacuum pipe layout.....
    Oct 2006
    Quote Originally Posted by ini View Post
    I'll have to do it tomorrow.....
    Where in Lancashire are you - I'm in Preston & cover the NW for my work - hopefully in the Avant once it's sorted.....
  7. Re: turbo vacuum pipe layout.....
    Oct 2006
    ini,
    Here's the offending pipe, circled in yellow - I think that it is supposed to return back into the air box somehow
    Another thought:
    - how can I manually check the turbo & the EGR actuators ? - can I suck on the actuator pipes - what should happen ?
    - what is the likelihood of the PCV's not working & can these be checked ? - when I blow up the vac pipes I can hear a rattle inside them
    I'm very tempted to go for the MAF, but would the MAF not working cause my engine to blow soot from the exhaust & be down on power, as though the turbo is nor working ?
    Mine does have the VTG charger - thanks for the detailed piccies
    Going to play with the turbo actuator & associated pipework today.
  8. Re: turbo vacuum pipe layout.....
    Vent line to air cleaner.If you have access to a diagnostic tool in measured value block you can get a reading of both the MAF and the turbo pressure.A faulty MAF will affect the turbo pressure.
  9. Re: turbo vacuum pipe layout.....
    Oct 2006
    Quote Originally Posted by kenney View Post
    Thanks for that - does it matter if it doesn't go jnto the air cleaner box ?
    I've just had the vac pipes off the EGR & turbo actuators - the turbo actuator has more vacuum that the EGR actuator......but on sayingthat I can't see if the actuator arm is moving even when I put a pipe directly onto the actuator to manually operate it.........
    Also - iv'e noticed when revving the car slowly (whilst parked) it gets up to 2500 RPM & then there is a click from under that dash - a relay or something........any ideas
  10. Re: turbo vacuum pipe layout.....
    I have a random pipe and also my car does that ticking sound like yours, have you found out where the pipe goes yet?
  1. Vacuum causes turbo & brake servo problems
    By barney2 in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 29-03-2008, 03:39 PM
  2. Turbo Pipe FOR SALE 1.8T BEX B6
    By powertuningsale in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 21-11-2007, 12:06 AM
  3. Pipe advice 1.8 Turbo
    By sp33dy in forum Chat - Anything with wheels
    Last Post: 13-10-2007, 03:32 PM
  4. a4 turbo de-cat pipe
    By A4 TURBO in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 05-07-2007, 11:34 AM
  5. Oil in Turbo charge pipe
    By rob1380 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 31-05-2007, 02:42 PM
