Thread: Starter motor on MK4 TDI REMOVAL and CLEANING OR REPLACING(HOW TO?)
  1. Starter motor on MK4 TDI REMOVAL and CLEANING OR REPLACING(HOW TO?)
    My Gt TDI 110 has a starting problem when cold it turns over really slow,but after use is fine.Have had the battery tested today and all is ok, next is the starter motor removal or replacement.How easy is it to remove and can it be removed from the top of the car or from the top and underneath and how many bolts hold it in place?
    Any help please as it needs sorting before it packs up for good!!!
  2. Re: Starter motor on MK4 TDI REMOVAL and CLEANING OR REPLACING(HOW TO?)
    1840 Post(s)
    It is very easy to remove and is done from above and below. If the starter is full of powdery debris, you have a dual mass flywheel problem. If you fit a new starter the same thing will happen again and starter motor manufactures are very aware of DMF induced failure and will not honour the warranty. Most starters now come with a waning in the box to this effect.
  3. Re: Starter motor on MK4 TDI REMOVAL and CLEANING OR REPLACING(HOW TO?)
    Thanks for that.Could it also be the coolant sensor?How many bolts hold the starter in place?and can the brushes,contacts and windings be cleaned??
  4. Re: Starter motor on MK4 TDI REMOVAL and CLEANING OR REPLACING(HOW TO?)
    1840 Post(s)
    The coolant temp sender won’t affect cranking speed. The motor is held onto the box by two bolts. It can be stripped down, cleaned and rebuilt if you have the time and skills.
  5. Re: Starter motor on MK4 TDI REMOVAL and CLEANING OR REPLACING(HOW TO?)
    Starter is being removed tomorrow to have a look.Hope it's ok.
    Thanks for the info Crasher
  1. Starter Motor
    By Ewster in forum Golf MK4 - 1999 - 2004
    Last Post: 09-03-2008, 11:06 PM
  2. Resetting ECU after cleaning or replacing MAF??
    By EmmettC in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 25-01-2008, 05:03 PM
  3. Starter motor
    By schteeeeveeee in forum Audi A3 - Archive Topics
    Last Post: 24-01-2008, 04:32 PM
  4. Serviced my starter motor
    By cbrpaul in forum Chat - Anything with wheels
    Last Post: 29-10-2007, 06:20 PM
  5. Starter motor on its way out ... ?
    By ash in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 07-09-2007, 11:58 PM
