Thread: Coolant Warning Light
  1. Coolant Warning Light
    Mar 2008
    Hi All
    Running a VW Passat 1.9TDI and having problems with coolant light.
    Wife started car in the morning (cold conditions) Coolant Light came on, with a stop message and reference to check coolant level.
    I checked car 2 hours later and no warning lights and coolant level was fine.
    Wife drove car for 2 days and no problems and no lights.
    Temperature gauge in normal position during driving.
    On 3rd day problem occurs again, although now the Warning light stays on with 'Check Coolant' message. again car is cold and has not been run.
    Would appreciate any advice. Please bear in mind a) I am new to VW's and the Passat b) my level of car diy ability is unfortunately poor
    Appreciate any help
    Wanna
  2. Re: Coolant Warning Light
    perhaps a faulty sensor? or even just a bit dirty on the contacts... or a loose wire. try unplugging the sensor and re-plugging it... or better still clean the contacts with a cotton bud and ethanol or something.
    Had the same issue on my old Golf mk4
  3. Re: Coolant Warning Light
    Mar 2008
    Thanks djsky
    This is where I show my lack of car diy.
    Which bit is the actual sensor ? and where do I find the contacts ?
    I've unscrewed the plug of the coolant container and then replugged, but which are the relevant bits.
    Apologies for my stupidity ?
    Wanna
  4. Re: Coolant Warning Light
    I would imagine it's a black connector on the side of the coolant container... i haven't had my passat that long, and it's over at the office at the mo, so i can't check i'm afraid.
  5. Re: Coolant Warning Light
    Mar 2008
    Thanks mate.
    Will have a look in the morning , when there is some light and hopefully no rain
  1. Coolant warning light, Passat 1.9 TDI
    By lancspassat in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 06-01-2010, 12:58 AM
  2. Coolant temperature warning light 1.8 turbo
    By The Stagg in forum Passat - B5 Forum - 1997 -2005
    Last Post: 03-12-2007, 02:55 PM
  3. Coolant warning reset
    By Nick Clark in forum Passat - B5 Forum - 1997 -2005
    Last Post: 06-07-2007, 11:16 AM
  4. VW Coolant Warning
    By brogandb7 in forum Passat - Archive Topics
    Last Post: 21-01-2007, 10:18 PM
  5. Golf MK3 Coolant Level & Temp Warning light
    By andyc567 in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 19-09-2006, 05:13 PM
