Thread: Scirrocco interior water leak
  1. Scirrocco interior water leak
    Mar 2008
    Hi there, does anyone have any ideas of likely cause of interior water leak. Carpet on both sides of transmission tunnel was saturated whilst parked for a few weeks. It's a '91 mk11. Any help greatly appreciated. Cheers.
  2. Re: Scirrocco interior water leak
    Sunroof drains, check the scuttle panel for leaves and standing water if full it will get into the car via the bulkhead grommets, also the door seals.
  3. Re: Scirrocco interior water leak
    A, A
    I have an issue at the moment on mine with wet carpets on the drivers side.
    I know its a diffferent car, but on my readings I have found it could be caused by one of the following.
    1. leaking washer water, check pipes
    2. door seals are out of place or need replacing
    3. water coming in through bulk head (most commom)
    4. heater matrix is leaking
    5. pollen filter is clogged, check for leaves and debris
    Im going to seal all of the entrances to the inside of the car later with silicone at the front of the car.
    Just another B7 Estate
  1. interior leak electronic fix
    By rwswll in forum Passat - B5 Forum - 1997 -2005
    Last Post: 07-05-2009, 11:27 AM
  2. water leak
    By mark740_5 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 17-01-2008, 11:37 PM
  3. scirrocco gt2 engine
    By outlaw56 in forum Scirocco - Corrado
    Last Post: 03-01-2008, 03:34 PM
  4. Water leaking to interior of 2005 TT
    By sadTT in forum TT - 8N Forum - 1998 - 2006
    Last Post: 30-10-2007, 01:18 AM
  5. water leaking into interior
    By scooby doo in forum Golf MK4 - 1999 - 2004
    Last Post: 28-04-2007, 12:22 AM
