Thread: led side lights and number plate lights, not working
  1. led side lights and number plate lights, not working
    Mar 2008
    Essex
    ater manageing at the weekend to get a way to get side lights out, i swapped the standard ones for led ones.i put one in and it worked, put the other side in to nd the passenger side had gone out, i turned the lights off then on and they worked for 4 to seconds then turned off, done this a few times and gave up so put it back to normal lights, they worked one side for bout a min and after turning them off and on they started t go back to normal,
    Is there no way you can fit led side lights,
    i had the same problem with the number plate lights too
    can anyone help
  2. Re: led side lights and number plate lights, not working
    Mar 2008
    Hi, I had the same problem. I did a few experiments and have cracked the problem. You need to put a resistor of 33 ohm in parrallel with each bulb. However you need a resistor which is large enough to dissipate the energy created by doing this. I bought a 25 watt 33 ohm resistor for a couple of quid which was incased in a heat sink and fitted nicely into the back of the headlight. The lights look absolutely amazing, i would highly recommend the mod. It only takes 30 mins tops and that was with a really tidy job.
    Scott
    Any more info email me. scott@marchwoodpower.com as i cannot access the forum very often
  3. Re: led side lights and number plate lights, not working
    Mar 2008
    check the power cumsumption of the led compared to standard 501, make sure it is not more it should be 10 times less!
  1. side lights
    By bigladwork in forum TT - 8N Forum - 1998 - 2006
    Last Post: 13-03-2008, 01:29 PM
  2. LED side lights
    By jb1999 in forum Audi A4 - Archive Topics
    Last Post: 27-01-2008, 07:13 PM
  3. Puddle Lights and courtesy lights not working
    By PerArdua in forum Passat - B5 Forum - 1997 -2005
    Last Post: 15-01-2008, 01:43 PM
  4. 51, 1.8T Passat - Number Plate Lights
    By martyn in forum Passat - B5 Forum - 1997 -2005
    Last Post: 18-09-2007, 03:40 PM
  5. Number Plate Lights???
    By bogey888 in forum Audi A3 - Archive Topics
    Last Post: 02-02-2007, 02:04 AM
