Thread: Mechanical Help Needed!
Results 1 to 10 of 15
  1. Mechanical Help Needed!
    Mar 2007
    Help!!!!
    My RS6 has developed a serious problem... and I'm looking for technical advice/guidance, just so that garages don't try to pull the
    wool over my eyes and con huge amounts of money from me!!! The car generally put the oil light on every couple of months, given
    that it does reasonably high mileage of 2.5k per month... so I top it up when it tells me to!, I do check the dipstick at the time to make sure it is telling me the truth though!
    The last time I did that, the light came on again the following day... and it had used a whole ltr of oil in about 50 miles!!! I replaced what it had appeared to use, and drove very gingerly for the rest of the day; having no option but to use the vehicle for work.
    It didn't use any more oil that day, so I used the car for the remainder of the week keeping an eye on it, still driving a little
    steady; and it didn't use any more oil. I was keeping the check for obvious signs of usage or leaks... no patches on the drive, and no
    apparent smoking as I drove along normally.
    At the start of the following week... there was one instance where I put the car on to turbo quite hard, just had to when getting out of a fix on a slip road!, and I noticed that it was making a distinctly different noise; not bumps and grinds, just that it sounded to be
    over boosting, i.e. that the whistle was definitely a much higher pitch. I glanced out the back, and sure enough it was smoking; not
    heavy, but enough to be noticable. I immediately stopped, turned around, and had a great excuse for working from home for the day!
    Thinking back to the night where it used a litre of oil... it was dark, and after putting the oil in, I was running rather fast to get
    home as it was late! So it may have been burning out the back, but a) I didn't think to look b) I daren't look, I was too busy
    concentrating on the world arriving in front of me at 100mph and c) there wasn't anyone following sufficiently close enough to me to see in their lights if it was burning or smoking.
    I took the car off the road... not sure what it was, but fairly sure that it was going to cost me a small fortune to fix it; and that
    would take a couple of months to pull together.
    Having talked to a few in the know (perhaps), I have had everything suggested;
    turbo has blown
    (but having had this happen to a 200sx a few years ago, they tend to blow smoke all the time once gone don't they?)
    a turbo valve has blocked
    (apparently there is a valve in a audi/vw turbo that is prone to blocking, and it is cheap to fix but expensive to get to!)
    faulty valve seals
    (the engine is known to be prone to faulty valve seals?... these will have gone, take it to a dealership being firm and the majority of at
    least the labour should be covered under warranty)
    From my take; it happened suddenly, it only seems to happen when on turbo, no smoke is apparent at any other time.
    Since I have taken it off the road, I have started it and sure enough it let out a belch when first fired... it hadn't been run for 3 weeks, and prior to that it was running daily.
    Does anyone have any experience or ideas as to what it may be?
    (Apologies now for going on so long!!!)
    Russ
  2. Re: Mechanical Help Needed!
    No age or mileage but here goes. This sounds as though you either have a breather vent problem, blocked with sludge or what ever and the sump is pressurising and is inhibiting the turbo scavenge oil return feed, or the Turbo is leaking oil, now you can remove the turbo output pipe going to the intercooler and see if there is excess oil in there, or it could be leaking into the exhaust side and burning off on the way out. Remove one of the plug and see if it is oiled or clean and dry. Regards Peter
  3. Re: Mechanical Help Needed!
    Mar 2007
    Quote Originally Posted by Peter D View Post
    Peter...
    Thank you so much for your advice, it is very very useful, and sounds about right as to what is happening.
    best regards,
    Russ
    PS...
    it's a 2002 RS6 Plus Avant, with about 100k miles
  4. Re: Mechanical Help Needed!
    "b) I daren't look, I was too busy concentrating on the world arriving in front of me at 100mph"
    On a private road of course......
  5. Re: Mechanical Help Needed!
    Niall, what are you on about. Regards Peter
  6. Re: Mechanical Help Needed!
    Jul 2007
    Cheshire, or my A6
    I don't get it either, Niall.
    Paul
    2003 Audi A6 1.9 TDI SE Sport. Blue. Black leather interior, sport pack, 17" 9 spoke alloys, Concert II HU, grey aluminium inlays, rear boot lip spoiler, S3 mirrors, CD changer, black leather arm rest & more.
    2004 VW Transporter T5 1.9 TDI SWB van. White. 16" Tangis alloys, front fogs, chrome buzz bars, Caravelle tail lights, CD changer, tow bar, roof rack, signwriting & more.
  7. Re: Mechanical Help Needed!
    Mar 2007
    Quote Originally Posted by paul b View Post
    I don't get it either, Niall. Paul
    I think the inference is that I shouldn’t be doing 100mph on a public road
  8. Re: Mechanical Help Needed!
    "I think the inference is that I shouldn’t be doing 100mph on a public road"
    No, I don't mind what speed you do - just may not be a good idea to post it on the net is all...
  9. Re: Mechanical Help Needed!
    May 2007
    Really Nial?
    04-03-2008, 07:42 PM Replies: 8
    Speed limiter?
    Posted By Niall76
    Re: Speed limiter?
    I can verify that Audi's do pass the 155mph mark. Mine has. I have confirmation from the boys in blue...
  10. Re: Mechanical Help Needed!
    Mar 2007
    Quote Originally Posted by Undercover View Post
    Really Nial?
    Speed limiter?
    Posted By Niall76
    Re: Speed limiter?
    ...Naill, can I call you kettle from now on, and you call me frying pan?
  1. 110 TDI mechanical whirring noise on ignition
    By Deadringer in forum Golf MK4 - 1999 - 2004
    Last Post: 08-11-2008, 03:21 PM
  2. Tuning Diesel - vw mechanical injection?
    By BugsyMalone666 in forum Chat - Anything with wheels
    Last Post: 13-03-2008, 09:22 PM
  3. Mk 2 Golf 1.3 '89:- electric or mechanical fuel pump?
    By jonnysb in forum Golf MK2 - 1984 - 1992
    Last Post: 25-01-2008, 03:17 PM
  4. MEchanical advice
    By holdgt in forum TT - 8N Forum - 1998 - 2006
    Last Post: 19-07-2007, 10:03 AM
  5. Drivers window mechanical fault!
    By Rogg in forum Passat - B5 Forum - 1997 -2005
    Last Post: 03-04-2007, 01:34 PM
