Thread: I got a headlight problem
  1. I got a headlight problem
    Feb 2005
    Someone please help, :got a mk2 gti 1987-88 if I turn the lights on when iginition is on the instrument panel goes dead ie. tacho and lcd clock die, but engine stays running, when I turn them off the check lights flash then all is normal, also the blue main beam light remains on while dipped in this mode and goes off when main beam is on! Checked the relay- good, and the flash switch- good, looked for the earth wire in the boot on the right ???????? Are there any other earths to check?
    Jan 2005
    Huddersfield
    I had this problem on my old 8v Golf and it turned out to be a short in the wiring at the back of the clocks. Best thing i can say is take the clocks out and have a really good look at them.
    Feb 2004
    Yorkshire
    46 Post(s)
    Only things I can think off that we had sort of "common" problems with were the printed circuits on the instrument cluster, the main light switch on the dash burning our, which effects the dimmer, or the wash wipe/indicator switches.
    May be worth just trying these as well.
    Stuart
    Stuart l VWAudi Forum
    VW Audi Forum - Founder
    Member of BMW Car Club GB
    Ways to support the website
  4. Thumbs up Got it sorted!
    Feb 2005
    Hi, thanks for the advice, looked around deeper into the trouble, found that I had left an earth wire from the rocker cover to the gearbox off!
    All sorted now anyway
    Thanks again.
  1. poor headlight a6
    By seahunter in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 12-04-2007, 05:17 PM
  2. Headlight Condensation
    By redmax90 in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 12-02-2007, 12:24 AM
  3. A4 Headlight
    By andrew00011 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 23-01-2007, 07:52 AM
  4. Audi A3 Headlight Problem
    By greglogan in forum Archive posts
    Last Post: 07-12-2006, 12:40 AM
  5. Headlight Dip problem
    By northness in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 12-10-2006, 08:09 AM
