Thread: bad gear oil leak
  1. bad gear oil leak
    Dec 2007
    rotherham
    help there is gear oil poorin out between gear box and engine on my mk3 golf gti it still drives but clutch is slipping its smokein from the engine and the gear oil smell is comin into the car. all i did was pull the car of the drive. any clue wots happend and what is the damage this might of caused
  2. Re: bad gear oil leak
    1841 Post(s)
    The differential has thrown out a rivet or the diff pin and punched a hole through from inside the box.
  1. Engine / Gear oil leak
    By Cooler_King in forum Golf MK2 - 1984 - 1992
    Last Post: 06-03-2008, 09:29 AM
  2. Help Please! 1st gear jumps out of gear
    By TollyTDI in forum Toledo
    Last Post: 17-06-2007, 07:50 AM
  3. Gear jumps out and non smooth gear changes
    By RIZWAN180 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 08-06-2007, 09:45 AM
  4. Footwell water leak / first gear is stiff
    By stejuk in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 02-06-2007, 11:03 PM
  5. Oil leak from the EGR
    By wilharper2000 in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 28-04-2007, 11:45 AM
