Thread: no codes displayed car will not start
Page 4 of 4 FirstFirst ... 234
Results 31 to 35 of 35
  1. Re: no codes displayed car will not start
    #31
    COILPACK???
    I had this on 2 golf's in the past. Usually about £50-60 from GSF
    Aparently a very common VAG fault. take 5 mins to change on a Golf GTI so would image it wouldn't be too hard to do
    98 Audi A4 TDI 110
  2. Re: no codes displayed car will not start
    #32
    Mar 2008
    Essex
    i had same problem! same symptons turning over ok but wouldnt allways start thought it was imobiliser.....
    turned out to be the battery wasnt holding a good charge...after a long run would start ok for a few days then failed to start (but still enough power to spin engine for 7-8attempts).
    worth a try most place's check em for free under heavy loads, cost me £45 for a new one and starts first time every time now!
  3. Exclamation Re: no codes displayed car will not start
    #33
    dub-a3 Guest
    Hi guys, i have a a3 1.8t on an r plate (AGU engine code)
    My car has recentley had problems starting (only in the morning when its cold - soon as its been running for a bit its fine).
    I have noticed that when i turn my ignition on before starting there is a strange buzzing coming from what seems to be my TB? - not too sure on exact position though as it was dark this morning when i checked.
    This is usually what happens when i go to start her,
    First attempt - usually just a click (no turn at all)
    2nd attempt - maybe 1 or 2 turns
    - this usually progresses until finally it starts after 5 or 6 attempts.
    It also will only start once this electrical buzz has stopped.
    Could this be a relay fault? would prob make sense to me if it was.
    Any help would be much apriciated!!
  4. Re: no codes displayed car will not start
    #34
    May 2008
    alright bud i had the same prob on my mk3 golf it turned out to be a relay
    hope it helps
  5. Re: no codes displayed car will not start
    #35
    1841 Post(s)
    Quote Originally Posted by dub-a3 View Post
    The throttle body should buzz but it may need removing, cleaning and readapting to the ECU. I think a fault code read and throttle body clean by a garage that knows how to do this will show what is causing the staring problem.
  1. New HDD-Disk Managment -Drive size is displayed as less???
    Last Post: 14-12-2007, 08:45 PM
  2. VAG codes help please!!
    By kaygolf in forum Golf MK5 - 2004 - 2009
    Last Post: 02-11-2007, 07:10 PM
  3. Another 2 VAG codes that don't mean anything to me!
    By andystratton in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 05-03-2007, 02:58 PM
  4. vag com codes
    By marty67 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 10-02-2007, 09:12 PM
  5. vag codes
    By new to vw in forum Passat - Archive Topics
    Last Post: 29-12-2006, 12:19 AM
