Thread: Drive Shaft oil seal
  1. Exclamation Drive Shaft oil seal
    john.learmonth@ Guest
    I need to replace the oil seal on the drive shaft/gear box nearside, but I need WW tools number 3109 and 201, where can I buy or borrow these?
  2. Re: Drive Shaft oil seal
    1840 Post(s)
    You can do it without those tools. The flange often springs off when the circlip is removed and if it doesn’t, it can be tapped off from behind and tapped back on after so you don't need VW201. If the flange does pop off under spring pressure I suggest you fit a new flange as the poor fit on the splines is what causes the oil leak and refitting a loose flange can be a trial without VW201. If you want the tools, you need a cooperative parts person at a VW dealer.
  3. Re: Drive Shaft oil seal
    Quote Originally Posted by john.learmonth@ View Post
    Thanks I will give that a try.
  4. Re: Drive Shaft oil seal
    Aug 2007
    if you want to save more money get the dimensions of the oil seal by reading them off the side and go to your nearest bearing shop. vw have silly mark-ups on parts like oil seals!
  5. Lightbulb Re: Drive Shaft oil seal
    Quote Originally Posted by mr brightside View Post
    if you want to save more money get the dimensions of the oil seal by reading them off the side and go to your nearest bearing shop. VW have silly mark-ups on parts like oil seals!
    " I already have a new oils seal , removing and fitting was my problem.
  1. drive shaft replacement
    By 9813gray in forum Passat - B5 Forum - 1997 -2005
    Last Post: 11-03-2008, 10:58 AM
  2. Drive-Shaft Problem?
    By RobDob in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 10-08-2007, 01:25 AM
  3. Drive Shaft/ Cv Joint
    By TANKSTER in forum Passat - B5 Forum - 1997 -2005
    Last Post: 13-07-2007, 11:45 PM
  4. drive shaft replace
    By vwray in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 02-12-2006, 09:29 PM
  5. drive shaft
    By vwray in forum Chat - Completely Off Topic
    Last Post: 14-11-2006, 06:10 PM
