Thread: 1993 Passat Estate GL 1984 CC
  1. Post 1993 Passat Estate GL 1984 CC
    Mar 2008
    Hi folks,
    Can anyone tell me the correct tyre pressure for normal driving for the above?
    and4545
  2. Re: 1993 Passat Estate GL 1984 CC
    Mar 2008
    In the manual for my 1994 Passat (as above) up to half load the front and rear are 2.1 Bar. Up to full load front should be 2.3, rear 2.9. This is for the 85kW enginge, with standard payload.
    If you've got a lower engine output or have the "Estate with increased payload" the figures differ slightly.
    I think the '94 Passat is slightly different to the '93 but I think the differences are essentially a "facelift" so I'd imagine the the tyre presures will remain the same?
  1. 1993 Passat Start Problem
    By oles99 in forum Early Passat Forum - Pre 97
    Last Post: 23-03-2009, 11:22 AM
  2. 00 Passat estate 18.T
    By hacksawcats in forum Passat - B5 Forum - 1997 -2005
    Last Post: 07-03-2008, 10:09 AM
  3. 1.8t passat estate MPG ?
    By beaucostil in forum Passat - B5 Forum - 1997 -2005
    Last Post: 05-12-2007, 02:29 PM
  4. 1993/J reg Indicator Stalk for Passat
    By Passat_Owner in forum Early Passat Forum - Pre 97
    Last Post: 10-09-2007, 10:52 AM
  5. passat tdi 130 estate
    By terryuk22 in forum Passat - Archive Topics
    Last Post: 27-12-2006, 01:49 PM
