Thread: emission control warning light
  1. emission control warning light
    Mar 2008
    hi all
    just making a short journey tonight and the emission control warning light came on.
    i only had the car serviced a month ago, its a 1.9 tdi 130 bhp a4
    any ideas on the cause and solution
    thanks in advance
    ian
  2. Re: emission control warning light
    May 2007
    you need to pull the fault codes, if it came on and stayed on.
    If it was on for a second or two while engine was cold I would not worry, this is not uncommon with modern engines
  3. Re: emission control warning light
    Mar 2008
    Quote Originally Posted by lonky View Post
    hi lonky
    thanks for the reply
    i had only travelled about a mile when it came on, it stayed on till i got home which is about another 2 miles.
    i have to drive 20 miles to work tomorrow on the motorway will it be safe to do so?
  4. Re: emission control warning light
    May 2007
    Driving with light on perminantly is not recommended, if mixture is wrong, damage to the cat can result. Damage to the engine other than this is unlikley.
    would see if light stays on when you next use it. If so would get it to garage ASAP
    The less miles the better.
    Once the unit is plugged into a diagnostics PC then the situation will be much clearer
  5. Re: emission control warning light
    Mar 2008
    cheers again lonky
    im going straight to the garage in the morning, they have VAG diagnostics there.
  6. Re: emission control warning light
    Mar 2008
    light went out after 30 seconds on my way to the garage
    drove to and from work (40 miles) no light
    went out on short journey switch on my windcreen blower and it has come back on!
  1. Emission Control System Warning Light (A4 Avant 1.9TDi 130PS AVF Multitronic)
    By trlaing in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 26-06-2008, 10:59 PM
  2. Emission Control System Light Warning
    By OliSmi in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 27-01-2008, 11:23 PM
  3. Emission Control System Warning
    By OliSmi in forum Archive posts
    Last Post: 07-09-2007, 01:43 PM
  4. emission warning light
    By walnut in forum TT - 8N Forum - 1998 - 2006
    Last Post: 06-07-2007, 02:02 PM
  5. Exhaust/Engine Emission Warning Light Constant Orange & EPC Light intermittent!
    By karl578 in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 07-06-2007, 10:59 PM
