Thread: Passat: 1978 "T"-- 1.6 estate
  1. Question Passat: 1978 "T"-- 1.6 estate
    Nov 2006
    Passat 1978 1.6 estate
    Hi. Does anyone know where I can get a
    water coolant temperature sender unit from?
    I think mine is faulty, my temp guage rockets to "high"
    after a few minutes driving, but the actual coolant temp is fine.
    The unit is simply a small "hexaganol bolt", with a single electrical
    spade connector at one end. The bolt screws into the engine block.
    Does it have a part number?
    Any help with this would be appreciated.
    Nov 2006
    scotland
    Hi. I'd go for exact one as fitted.Even at dealer ,it wo'nt break the bank
    Nov 2006
    Thanks Jak. Yeh, but my dealer sez he can't them..
    ..model now sooooo old!
    london/ UK
    Did you tried cleaning the sender part that stays inside the engine and the electrical conector? You could try ebay as there are people thet sell second hand parts/new old stock for cars of that age. Will look into a different model/year as they were used troughout the range and one might found the same sensor on a newer model. Failing that take your old sensor out and find one from a newer model and have a garage make it fit(drill new hole in the block and thread-it ) . Hope this helps.
    May 2006
    Exmouth, Devon, UK. Drives Bonkers Fabia Diesel. Has full VCDS
    Nice to see there's still some of the first passats on the road.
    Not sure if trawling second hand spares places is any good? www.247spares.co.uk
  6. Smile
    I had a 1986 Passat I broke the temp sender connector, your one sounds the same type. Managed to get a new sender unit from the VW dealer (even in stock) BTW this was three years ago.
  1. Audi A4 Avant - Panel Display - "In 1 "or "In 2"
    By infrance in forum Audi A4 - Archive Topics
    Last Post: 05-03-2007, 03:20 PM
