Thread: Susoension Rattle? Check your brake pads
  1. Susoension Rattle? Check your brake pads
    Jan 2008
    After research about suspension problems on bora and golfs to try and find out what was making an almighty racket on my car i found pads/clips can be an issue.
    Went out for a quick nosey and managed to track down the problem - indeed, my pads are rattling.
    Now im expecting one of two things -
    1 - the antirattle clip isnt on properly
    2 - the pads are just plain crap. they where only changed a month or two ago, bought them from a normal motor factors. Anyone had a problem with ill fitting pads?
    I must point out that the rattle appeared a few weeks after changing the discs and pads, and has got steadily worse.
    Would anyone happen to have a pic of the caliper with the clip on so i can see what it is supposed to look like when it is properly attached?
    I would go out and take wheel off and have a look but im at my flat and all my tools are at home
  2. Re: Susoension Rattle? Check your brake pads
    Apr 2007
    In the "How to" section, there is a very good post on changing front brake discs and pads. There are some good pics on there that might be useful to you.
  1. Golf MK4 - "Check brake pads" + Essex servicing?
    By bsdbm in forum Golf MK4 - 1999 - 2004
    Last Post: 11-10-2009, 09:31 PM
  2. Rattling suspension? Check your brake pads
    By dirtyderv in forum Golf MK4 - 1999 - 2004
    Last Post: 07-03-2008, 06:42 PM
  3. can the check brake pads message be cancelled?
    By thee gaffer in forum Passat - B5 Forum - 1997 -2005
    Last Post: 18-01-2008, 10:48 AM
  4. Check Brake Pads Warning Light
    By collieboy in forum Golf MK4 - 1999 - 2004
    Last Post: 15-11-2007, 08:23 PM
  5. Check Brake Pads Warning
    By Caribbeanwind in forum Passat - Archive Topics
    Last Post: 28-04-2007, 12:59 PM
