Thread: VW Golf MK4 130bhp Dual Mass Flywheel Problems
Page 3 of 14 FirstFirst 1234513 ... LastLast
Results 21 to 30 of 136
  1. Re: VW Golf MK4 130bhp Dual Mass Flywheel Problems
    #21
    Quote Originally Posted by Kunal View Post
    the ticking noise, did it come from the front slighty on the right hand side of the engine. but at the bottom? i had that tickin noise aswell. its something gt to do with the clucth or the flywheel.
    A DMF knocks more thn ticks, and is more noticable on engine shut off as it bounces around after the crank has stopped.
    2019 Urus, 2020 RS7
    2014 RS6, 2018 RS5, 2016 RS3, 2019 RS3
    2011 RS5, 2008 S5 V8
    2007 A4 2.0, 2008 Passat 2.0 TDI
    2005 Bora 1.9 TDI, 2000 Bora 1.6 , 1989 Polo 1.4
  2. Re: VW Golf MK4 130bhp Dual Mass Flywheel Problems
    #22
    Mar 2007
    U-96
    Hi Paul,
    So what form of abstract art is a clutch / DMF ?
    Vivid colours particularly the Thai / Phucket pictures!
    TR7
  3. Re: VW Golf MK4 130bhp Dual Mass Flywheel Problems
    #23
    Quote Originally Posted by tornadored7 View Post
    Hi Paul,
    TR7
    aye, some sherman dreamt DMF up years ago.
    funny you should say that though - I'm currently working on a large abstract of a clutch for the reception of a clutch manufacturer
    2019 Urus, 2020 RS7
  4. Re: VW Golf MK4 130bhp Dual Mass Flywheel Problems
    #24
    galway ireland
    am noy sure what do do about the noise u can actually hear a nearly """clacking noise""more in middle of car!!! garage that sold it to me is not giving me any faith in which to ask him to fix it....
  5. Re: VW Golf MK4 130bhp Dual Mass Flywheel Problems
    #25
    Quote Originally Posted by finngalway1 View Post
    Well, IMO, its either the DMF, or gearbox bearing. Both expensive jobs to fix. If gearbox, it could last like that a long time before going spectaculary and costing much more. If DMF its likely to deteriorate quickly.
    2019 Urus, 2020 RS7
  6. Re: VW Golf MK4 130bhp Dual Mass Flywheel Problems
    #26
    galway ireland
    ya i think i will be out of pocket again!!!! have you any idea of best to phrase this to dealer and is it covered under a warranty????
  7. Re: VW Golf MK4 130bhp Dual Mass Flywheel Problems
    #27
    Southampton, Hampshire
    so a rattling coming for the front of the car, somewhere in the middle of the dash when gears are engaged could be gearbox bearing?
    Rob
    '01 Bora TDi130 Sport
  8. Re: VW Golf MK4 130bhp Dual Mass Flywheel Problems
    #28
    Dont mention the word 'warranty' to start with - and let them know that you understand that they didnt make the DMF, but 'have the manufactures of the dmf acknowledged an issue' or similar. Use the phrase manufacturing defect rather than warranty
    It could be either a sachs or LuK unit on here incidentally.
    If they blame driving style, ask them how. The correct answer is either slipping the clutch/holding on the bite point too long/driving with foot on the clutch pedal and therefore heating the DMF up too much. Or possibly driving in too high a gear for the road speed - but id fall off me perch if they knew that one
    2019 Urus, 2020 RS7
  9. Re: VW Golf MK4 130bhp Dual Mass Flywheel Problems
    #29
    galway ireland
    rite, gt call from the garge and she's ready to be picked up tomorrow!!! in total i spent £476.15 with a new DMF and a whole new clucth kit. which i brought from euro car parts. all though they had to order one more part which i cnt remember what it was. which was about £30. i will test drive the car nd keep you posted, hope all this info was good.
    yeah thanks
  10. Re: VW Golf MK4 130bhp Dual Mass Flywheel Problems
    #30
    Worcestershire, UK
    I've had what sounds like the same problem on my mk4 golf...rattling / vibrating / clunking noises when the car is engine braking, that quiet down when you engage the clutch.
    I had my mechanic take it for a drive and he said it was a noisy differential, which is a sign that its on the way out. i thought i'd get a 2nd opinion so took it to a gearbox specialist yesterday - he immediately recognised the noise and basically said that the differential bearings and pinions need replacing. to cut a long story short he is going to rebuild the differential for £250 (thats a days labour and parts), however thats excluding removal and refitting of the gearbox.
    It might be worth you doing something similar - i.e. see a gearbox specialist. if you do have this problem then you have one of three options:
    1. buy and fit a brand new gearbox...about £1500 - £2000 (VW's quote, fitted)
    2. buy a second hand or reconditioned gearbox...about £300 - £600 + fitting
    3. get your box rebuilt...as above (but don't know how cheap / expensive that quote is as its the only one i have)
    hope this helps.
  1. Advice required on Dual Mass Flywheel - Golf 1.9 TDI MK5
    By Scoobypoo in forum Golf MK5 - 2004 - 2009
    Last Post: 10-05-2008, 12:11 AM
  2. Dual Mass Flywheel
    By seventh-heaven in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 06-11-2007, 07:19 PM
  3. Dual mass flywheel problems
    By Gully in forum Passat - B5 Forum - 1997 -2005
    Last Post: 19-09-2007, 11:28 AM
  4. dual mass flywheel
    By jimbob in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 30-06-2007, 01:22 PM
  5. Dual Mass Flywheel
    By Richardm in forum Passat - Archive Topics
    Last Post: 27-03-2007, 02:54 PM
