Thread: Wet (VERY !) Polo
  1. Wet (VERY !) Polo
    missesbell Guest
    Some time ago I wrote about our daughters Polo being VERY wet in the offside footwells. I got some help from the forum but little from our local dealer who insisted it would be the door seals as they said the near side door seal was damaged and needed replacing. Having pointed out to them that the water (At least two pints) was on the off side and that it was unlikely to be jumping across the car, they renewed the door seals, tested the car, having dried it out (£300 just to dry it) They then applied the pressure hose to discover a hole in the bulkhead which was allowing water to "pour in " This took the bill to over £600. They have agreed to knock 30% off this bill but would like to know if anyone else has had the same problem and any views on the inability of the garage to listen to their customer.
  2. Re: Wet (VERY !) Polo
    sounds like they screwed you good and proper. if i were you i wouldnt pay for the door seal you didnt need (unless you agreed to the work)
    how old is the polo just out of interest?
  3. Re: Wet (VERY !) Polo
    missesbell Guest
    The Polo is just over 4 years old. I have now spoken to VW customer service......Watch this space !
  4. Re: Wet (VERY !) Polo
    good luck with getting some cash back. wouldnt have expected that on a 4 year old polo! just goes to prove they arent as well built as they used to be
  1. Club Polo & Performance Polo sho
    By stuart in forum Shows & Events
    Last Post: 18-07-2004, 03:47 PM
