Thread: Audi A6 Avant 1.9tdi 130pd turbo not working
Results 1 to 8 of 8
  1. Audi A6 Avant 1.9tdi 130pd turbo not working
    Oct 2006
    hello all, my car has an intermittant fault. The turbo kicks in when it feels like it. I have had it tested via a vag.com on the move. no faults found. The boost pressure is ok the amount of fuel mixed is ok. the maf is ok. the egr valve is ok. the turbo is ok. all valves are ok. vacuum is ok. When the car works ok the performance is staggering. When the car does not run ok the performance is of a 100bhp engine.Anyone any ideas?
    Oct 2006
    Post some logs taken on the run, we'll see...
    Oct 2006
    My audi is 2002 model with 117k miles.This is the first time i have owned a diesel. a week after purchasing the car it would not accelerate above 80mph so the maf was replaced with a reconditioned one. This cured top end speed but did little for low level grunt. Occasionally, the car will take off in all gears and across the rev range and the power of this is exhilerating like being pushed along. Is this normal? Under ordainary driving the car requires lots of throttle and feels like it is underpowered. Am i asking for too much out of my audi?
    Oct 2006
    It's hard to say what is the problem without trying it. If you live nearby west london maybe pop by sometime and you'll try my A6 110PS and i'll try your .
    Oct 2006
    Thanks for that etronic that is what i need to do so i can compare. Problem is i live in yarm teesside. What niggles me is sometimes the car really goes and is obvious the turbo is working well, all other times it pulls but no where near as good.
    Oct 2006
    The problem was a faulty microchip diagnosed using a rolling road and diagnostics. A new one is fitted and all is ok now!
    Yorkshire
    N75 valve?
  8. Re: Audi A6 Avant 1.9tdi 130pd turbo not working
    May 2008
    Quote Originally Posted by barney2 View Post
    hi mate,where did you go as i might need to take mine there,im in boro too :-)
    what did you get changed?,what was the fault?
  1. Audi A4 1.9TDI 100bhp TURBO CHARGER NEEDED!!!
    By cha3 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 07-06-2007, 11:41 PM
  2. Audi A6 Avant 1.9TDI 115 se without CD!!!!
    By crashball75 in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 01-04-2007, 03:48 PM
  3. AUDI A4 Avant 1.9TDi Sport
    By Dazbroker in forum Audi A4 - Archive Topics
    Last Post: 17-02-2007, 12:09 AM
  4. Audi A4 1.9tdi lack of turbo boost
    By DRCDG in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 18-07-2006, 01:07 PM
  5. Audi A4 1.9tdi lack of turbo boost
    Last Post: 12-06-2006, 11:11 AM
