Thread: speaker upgrade A4
  1. speaker upgrade A4
    Oct 2006
    Hi guys
    I have the A4 2004 model. It's the basic concert system. Any advice on how to get the sound so much better? I must admit it's far better than most Manufacturers basic system. I know it's got a small sub speaker in the centre of parcel shelf also. What would be a not so expensive way to get great sound. possibly just change the speakers. Not sure on adding amps but id need be!
    Thank for reading post
    Hope to hear from you soon.
    Stuart
    Nov 2006
    Oldham, Manchester, UK
    I'm sure you can buy quaility component speakers that are made to replace the factory fitted speakers.
    These are generally higher powered with better sound quality although where they are mounted and how well they are boxed makes a huge difference to sound quality.
    The only manufacturer of factory fit component speakers I can think of at the moment is Pioneer but I'm sure there are others. Ask at your local (if you have one) car audio centre, they should be able to make some suggestions and give you a sound you will be more than happy with.
    london/ UK
    Halfords does sell Autoleads speaker ring adapters that will alow you to fit any 13" speaker. Get a good set of Focal or MB Quart components for the front dors and you are all set. Go for a 12" sub and a min of 300W RMS DIGITAL AMPLIFIER(fusion does a nice kit-if you happy with the colour-available at Halfords) to compliment the sound stage and ditch the standard head unit(you will need to get an adaptor set to fill the gap as the standard audi dash opening is wider than OEM). Do not worry about the rear door speakers for now...Hope this helps.
  1. A3 speaker upgrade
    By squinty in forum Archive posts
    Last Post: 16-05-2007, 04:39 PM
  2. Speaker resonance
    By spiderlover in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 22-03-2007, 05:53 PM
  3. Speaker sizes?
    By tweeky in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 20-03-2007, 06:20 PM
  4. A4 Dodgy Speakers - Speaker Upgrade
    By Mairtin in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 14-01-2007, 02:02 PM
  5. Speaker upgrade
    By fenian672000 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 22-11-2006, 11:20 AM
