Thread: Guess This :glowing Red Hot Exhaust What Is The Cause Of The Problem
Page 3 of 3 FirstFirst 123
Results 21 to 26 of 26
  1. Re: Guess This :glowing Red Hot Exhaust What Is The Cause Of The Problem
    #21
    YES YOU' VE GOT IT NOW
    FIRST OF ALL ADDED SOME CAT CLEANER (IN THE HOPE OF CLEANING THE CAT)- BUT NO LUCK
    CHANGED CATALYTIC CONVERTER- BUT NO LUCK
    CHANGED THE LAMBDA SENSORS- BUT NO LUCK
    NEW SPARK PLUGS CHANGED (BUT LATER FOUND OUT THAT THE ONE WHICH WAS A BIT DIFFICULT TO REMOVE HAD NO SPARK)
    LEADS WERE CHANGED - BUT NO LUCK
    FINALLY THE COIL PACK (WHERE LEADS CONNECT TO ) WAS CHANGED AND HEY PRESTO JOB SORTED, CAR WAS PERFECT.
    IN ADDITION WHAT MADE MATTERS WORSE WAS THAT THE SIGNS THE CAR WAS GIVING WERE LEADING TO FALSE SUGGESTION.
    I.E OIL RESIDUE ON SPARK PLUGS, DIPSTICK AND OIL TOP BEING VAGUELY COVERED IN CREAM, BLUE SMOKE WHEN STARTED CAR FROM COLD THEN NO SMOKE AT ALL ETC.
    BUT CONGRATULATIONS TO THOSE WHO FIGURED IT OUT.
  2. Re: Guess This :glowing Red Hot Exhaust What Is The Cause Of The Problem
    #22
    nottinghamshire
    Quote Originally Posted by A3 SPORTQUATTRO View Post
    WHY WOULD THE DIPSTICK AND OIL FILLER CAP BE COVERED WITH CREAM IF IT WAS JUST THE COIL??
    DOES THIS NOT MEAN OIL AND WATER ARE MIXING SOMEWHERE??
  3. Re: Guess This :glowing Red Hot Exhaust What Is The Cause Of The Problem
    #23
    Dec 2006
    Manchester
    Not always...
    Condensation builds up inside the engine if if only used on short journeys a lot.
    1.9 tdi PD 100 Bora
    110cc pitbike, 4 speed semi-auto
    110cc Off road buggy, 4 speed semi-auto
  4. Re: Guess This :glowing Red Hot Exhaust What Is The Cause Of The Problem
    #24
    sheffield on sea
    i had a similar problem with a volvo one of the ignition coils packed up so it was only running on 2 cylinders,and because of all the unburnt fuel in the exhaust it fried the cat.
  5. Re: Guess This :glowing Red Hot Exhaust What Is The Cause Of The Problem
    #25
    Hyde
    Quote Originally Posted by chris.fulton View Post
    First thing I'd do is change/clean the spark plugs because if some unburnt fuel was getting into the exhaust system then igniting in the exhaust due to the heat, this could cause the exhaust to glow red hot.
    What would suprise me about this suggestion is that there is no oxygen in the exhaust system in order to facilitate a burn or flame, the fuel oxy mix is burnt in the cylinder and there should be nothing left there after, you did not say the car had a misfire as far as I can read, indicating it was running on all four..
    Interestinly A3, you do have some problems with your vehicles eh
    https://www.vwaudiforum.co.uk/forum/s...ad.php?t=26085
  6. Re: Guess This :glowing Red Hot Exhaust What Is The Cause Of The Problem
    #26
    Nov 2015
    West Wales
    Im looking at a skoda fabia today with the same problem. Fingers crossed this thread will be the answer
  1. A4 1.8t Part in my engine glowing red. any ideas??
    By spm in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 23-11-2007, 12:41 AM
  2. A6 Handbrake Light glowing with engine off
    By lcs in forum Audi A6 - C4 Forum - 1994 - 1997
    Last Post: 10-03-2007, 04:58 PM
  3. Guess the car
    By MalcQV in forum Chat - Completely Off Topic
    Last Post: 18-12-2006, 11:59 PM
  4. VW Cat Convertor Glowing Bright Red
    By DieselTrader in forum Archive posts
    Last Post: 11-10-2006, 11:45 PM
