Thread: Guess This :glowing Red Hot Exhaust What Is The Cause Of The Problem
Results 11 to 20 of 26
  1. Re: Guess This :glowing Red Hot Exhaust What Is The Cause Of The Problem
    Have you tanked diesel insted of petrol. Check if your neighbours cat has gone missing,might be wrapped around your timing.
  2. Re: Guess This :glowing Red Hot Exhaust What Is The Cause Of The Problem
    Dec 2006
    Manchester
    Quote Originally Posted by A3 SPORTQUATTRO View Post
    SO ACCORDING TO ALL YOU GUYS
    • IVE CHANGED THE CATALYTIC CONVERTER BUT NO LUCK
    • IVE PUT 3 NEW SPARK PLUGS (1 of them i found difficult to change so left it for the moment), the result was that they were covered in thick oil residue, even with the new ones these are being covered with the same thick oily residues.
    WHATS MY NEXT STEP
    Nope... Should of scanned it first Judging by the way this thread is panning out, it sounds like theres going to be a dodgy little sensor at fault at a cost of about 50P from VW shipped from germany.
    1.9 tdi PD 100 Bora
    110cc pitbike, 4 speed semi-auto
    110cc Off road buggy, 4 speed semi-auto
  3. Re: Guess This :glowing Red Hot Exhaust What Is The Cause Of The Problem
    Engine Fuse Blowed The Once And Never Even Once After This
    (please Note This Is No Trick Question And There Is No Tricky Answer To This Topic, If This Is Of Any Help)
  4. Re: Guess This :glowing Red Hot Exhaust What Is The Cause Of The Problem
    Also Has Not Had The Wrong Fuel Put In.
    Btw I Forgot To Mention The Engine Management Light Is Also On
  5. Re: Guess This :glowing Red Hot Exhaust What Is The Cause Of The Problem
    nottinghamshire
    just tell us what was wrong with it!
  6. Re: Guess This :glowing Red Hot Exhaust What Is The Cause Of The Problem
    Give us another hint has is anything to do with damage because of animal bites,and i was only joking about the cat
  7. Re: Guess This :glowing Red Hot Exhaust What Is The Cause Of The Problem
    #17
    OKAY THEN I WILL TELL YOU BUT TOMMORROW
    THIS WAS EXACTLY HOW I WAS FEELING WHEN I USED TO PAY FOR REPLACING PARTS THAT WERE NOT FAULTY
    BUT IF YOU WANT A HINT EXPAND THE TOPIC REGARDING SPARK PLUGS.
    (THIS IS STILL NO TRICK QUESTION, BUT I TAKE IT AS NOT MANY HAVE EXPERIENCED THIS PROBLEM)
  8. Re: Guess This :glowing Red Hot Exhaust What Is The Cause Of The Problem
    #18
    nottinghamshire
    your not the only one who has paid to replace parts that dont need replacing, what other choice do you have if the fault doesn't show up on vag com
  9. Re: Guess This :glowing Red Hot Exhaust What Is The Cause Of The Problem
    #19
    WHATS MY NEXT STEP
    oily residue...valve seals or piston rings gone...or spark plugs not getting enough power to give an effective spark hence fuel being partialy combusted and pumped out of the cylinder during exhoust phase...collecting in the cat and due to heat it ignites hence red hot cat cassing.....check and if necessary change plug cables/check and if necessary change ignition coil aka coil park/remove ALL plugs and change to specified/correct plugs
  10. Re: Guess This :glowing Red Hot Exhaust What Is The Cause Of The Problem
    #20
    gklute Guest
    im no expert... but i had the same problem on my megane coupe... it wud drop power and the cat wud over heat.
    i also changed cat.. checked the spark plugs....
    what it turned out to be was the coil... (other end where the spark plugs plug in to)
    you should hook it up to a diagnostic computer to source the problem i wasted cash on chaging the cat when i didnt neeed to!
  1. A4 1.8t Part in my engine glowing red. any ideas??
    By spm in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 23-11-2007, 12:41 AM
  2. A6 Handbrake Light glowing with engine off
    By lcs in forum Audi A6 - C4 Forum - 1994 - 1997
    Last Post: 10-03-2007, 04:58 PM
  3. Guess the car
    By MalcQV in forum Chat - Completely Off Topic
    Last Post: 18-12-2006, 11:59 PM
  4. VW Cat Convertor Glowing Bright Red
    By DieselTrader in forum Archive posts
    Last Post: 11-10-2006, 11:45 PM
