Thread: Parcel shelf slipping off
Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 31
  1. Re: Parcel shelf slipping off
    #21
    Aug 2007
    Newport, Wales
    7 Post(s)
    Or how about something simpler.. which should never get in the way...
    Attach some form of peg to the inside of the tailgate to prevent the flap from nodding?
    [ My Cars: 2011 Caravelle SE TDI (140) LWB | 2015 L200 Barbarian 2.4 DI-D | 2015 Mini Cooper SD ]
    [ Past Audis:
    A6 S-Line 3.0
    V6 TDI Qttr | A4 3.0 TDI Qttr S-Line | S6 4.2 Qttr | A4 2.5 V6 TDI Qttr Sport | A4 1.9 TDI Qttr S-Line | A4 SE 2.0 TFSI Quattro Avant | 2.0 TFSI Roadster ]
    [ Past VWs: Mk1 GTI Cab | Mk3 2.0 Cab |
    Mk3 VR6 | Mk4 R32 | Mk4 V6 MoFo | Mk4 Golf 1.9 TDI| Mk4 Supercharged 2.0 6-speed | VW Touran 2.0 TDI DSG ]
  2. Re: Parcel shelf slipping off
    #22
    May 2009
    Glasgow
    Quote Originally Posted by toff View Post
    That's what I planned to do at first! I ended up thinking it would take far too long to position the thing accurately. You would have to climb into the boot from the back seats with the load cover closed, with a torch in your mouth...
    Then I'm not sure if the peg on the tailgate would keep hitting the load cover when you slam it shut. That's how I ended up with the solution I have, it only took 5 minutes to drill and tap a hole.
    Whatever you end up doing, I'd be interested in seeing some photos!
  3. Re: Parcel shelf slipping off
    #23
    May 2009
    Glasgow
    As you suggest, I'm gonna try to come-up with a different take on what you've done, somehow using suspended magnets to prevent the overhaning flap from nodding...
    Now I'm thinking magnets could be a good idea... You could attach a magnet to the rear edge of the parcel shelf, and another on the inside of the tailgate. If you can make the gap small enough, and the magnets are strong enough, it could stop the thing from nodding.
    The magnet on the parcel shelf would have to be small and light, maybe a "rare earth" magnet,
  4. Re: Parcel shelf slipping off
    #24
    Aug 2007
    Newport, Wales
    7 Post(s)
    Quote Originally Posted by Stuart7 View Post
    Ah.. I take your point about the pegs hitting the flap. I guess you'd just have to ensure the flap is perfectly horizontal before closing the tailgate each time.
    Re: the other approach: yup.. I was thinking rare-eath magnets.
    Perhaps rare-earth magnets attached to the plastic on the inside of the tailgate (so they aren't even visible) and some more neatly attached to the underside of the overhanging flap.
    You can get some with wire attached (to bridge the gap to the tailgate if necessary).
    The only consideration is: when you open the tailgate, will the roller-cover be yanked out of place! I guess getting the strength of the magnets right (or the distance apart) is critical.
    Al.
    [ Past Audis:
    A6 S-Line 3.0
  5. Re: Parcel shelf slipping off
    #25
    Coventry
    interesting.... mine is a 57 reg and has not done this yet. It is possible that audi have redesigned the parts since ..... i'll post photos of mine fro you to compare to your own.
    another suggestion, could the spring that rolls the blind in be weak? the weaker it is would allow the nodding action to draw more blind off the roll thus giving it sufficant slack to allow vertical or lateral movement.
  6. Re: Parcel shelf slipping off
    #26
    Cork
    For whats it's worth, this happened to me the other day, had the car a few weeks, i heard this wooash-bang.. nearly sht myself.. the previous owner used insulating tape, but this had worn a little, so i just slipped on 2 tubes of adhesive heatshrink , heated it on, the put the shelf in placed.. hasn't moved since..
  7. Re: Parcel shelf slipping off
    #27
    Sep 2007
    Essex boy in Suffolk
    Quote Originally Posted by defsix View Post
    Good idea, I'll try that one later.
    Graham
    Still pretending to know stuff.
    Golf 6 .:R
    Corrado 20vT - BBS RCs, Leather, Bremo's, TFSI and DSG
  8. Re: Parcel shelf slipping off
    #28
    Sep 2009
    cheltenham
    I have made the slots longer with a drill by 3 or 4 mm no more problems.
  9. Re: Parcel shelf slipping off
    #29
    Sep 2019
    Latvija
    Can you show please
  10. Re: Parcel shelf slipping off
    #30
    Sep 2019
    Latvija
    How did you do that?
    Quote Originally Posted by sketr1 View Post
  1. new Tonneau cover/Parcel shelf :Fitting it!!
    By PopDorset in forum Touran - Sharan - Caravelle
    Last Post: 05-08-2014, 05:12 PM
  2. A3 Parcel shelf
    By wheely in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 31-01-2008, 04:26 PM
  3. Parcel Shelf MYstery
    By wimbledonboy in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 24-11-2007, 10:37 AM
  4. parcel shelf
    By seandredlock in forum Arosa
    Last Post: 18-06-2007, 02:00 PM
  5. Rear parcel shelf speakers
    By PaulA4 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 31-05-2007, 11:44 PM
