Thread: engine fault code ?????
  1. engine fault code ?????
    Brynsadler South Wales
    Hi all,can anyone help,red warning light came up on the dash of my 54plate passat 100 highline with "engine...workshop" plugged in my code reader and comes up with 16955 but i cant find out what the code is for...thanks..dave
  2. Re: engine fault code ?????
    Dec 2007
    West Sussex
    This is what I found (you;ve got the source at the bottom):
    16955/P0571/001393 - Brake Switch (F): Implausible Signal
    Possible Symptoms
    • MIL burning
    • No Brake Lights
    Possible Causes
    • Wiring and/or connections faulty
    • Fuse defective
    • Wrong brake light present (21W in stead of 5/21W)
    • Brake Light(s) defective
    • Brake Switch (F) defective
    Possible Solutions
    • Check wiring and/or connections
    • Check / Replace Fuse
    • Check / Replace Brake Lights
    • Check / Replace Brake Switch (F)
    Special Notes
    • In Europe at VW-cars the Brake Switch (F) had the bad reputation of breaking down often
    Retrieved from "http://wiki.ross-tech.com/index.php/16955/P0571/001393"
    Rob
  3. Re: engine fault code ?????
    wow thanks for the quick reply rob....i was thrown when it came up engine fault and only seems to happen when stuck in traffic...i`ll check the brake light as soon as the rugby`s over and let you know......thanks again
    just checked the brake light are working ok...unless theres an intermittent fault....any ideas about the "mil burning" part of the code????
  1. Another Fault code.. VAG-COM - ENGINE - Can you help?
    By RickT in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 24-12-2008, 09:19 PM
  2. Engine starting problems Vag code fault codes listed
    By MCCLATCHIE in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 29-02-2008, 10:06 PM
  3. Replies: 0
    Last Post: 15-01-2008, 01:07 AM
  4. `94 1.8 Driver - Fault code/issue ABS engine
    By BugsyMalone666 in forum Golf MK3 - 1993 - 1999
    Last Post: 22-11-2007, 05:18 AM
