Thread: audi 80 cold start problem
  1. audi 80 cold start problem
    Mar 2006
    ayup
    my 94 80 2.0e has started to have issues starting from cold. on your first attempt to start it usually will not fire up, then starts on the second or third attempt it starts but you have to let it idle for twenty seconds or so before pressing the accelerator otherwise it will cut out. a mate suggested to me it might be the cold start valve any one got any ideas?
    cheers chris
    Aug 2006
    Notts
    Sounds like the cold start regulator is at fault here. Not 100% sure for the 2.0, but its normally attached to the side of the engine and uses beeswax to respond to temp of the engine and to adjust the fuel mixture accordingly. I suugest you source a replacement from a scrapyard. They are fairly easy to install too.
  3. colds start regulator
    Mar 2006
    its been i while but i still haven't sorted my cold start issues. am still unsure of the location of the cold start regulator have had a good look round the engine block. also got a mate to check his auto data discs but it doesnt cover late 80's any one got any ideas on where it is and what it looks likes.
    Aug 2006
    Notts
    Not sure if this will help you but heres a pic:
    http://images.google.co.uk/imgres?im...l%3Den%26lr%3D
    You may get more info from a Bosch K-jetronic workshop manual. I believe Haynes do one but theres loads of info on the net.
    Heres a site i used when i had a merc 190e which has the same fuel system:
    http://www.justanswer.com/JA/ASP_A/T...-benz-190e.htm
    They are usually attached to the the front of the block. That on the rhs as u look from the front of the car, same side as the spark plugs are on. It should be clearly visible. If u still cant find it, track the fuel lines from the fuel distributor unit (it will have 6 braided pipes for a 4 cylinder i think) which is attached to the air filter housing.
    Let em know how u get on. Good luck and Happy Xmas
    Jp
    Mar 2006
    cheers for the advice and links mate im thinking it may be the thermo time switch after doing a bit of reading
  1. Cold Start Problem Tdi 110 Golf ???
    By robdcaterham in forum Golf MK4 - 1999 - 2004
    Last Post: 18-12-2007, 01:55 PM
  2. Cold Start Problem
    By robdcaterham in forum Archive posts
    Last Post: 21-03-2007, 07:24 PM
  3. cold start problem on A4 99'
    By wescyj in forum Audi A4 - Archive Topics
    Last Post: 23-01-2007, 10:49 PM
  4. Cold Start Problem
    By Cam in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 22-01-2007, 03:33 PM
  5. 1992 MK3 Golf 1.8 CL - Cold Start Problem
    By drillyourownhole in forum Golf MK3 - 1993 - 1999
    Last Post: 06-03-2006, 03:55 PM
