Thread: Help A3 Unable to select Reverse Gear
Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
  1. Re: Help A3 Unable to select Reverse Gear
    curiousgeorge Guest
    I get this occasionally with mine, I also got it with my old Honda Civic. I just select first and then I'm usually able to get into reverse.
  2. Re: Help A3 Unable to select Reverse Gear
    134 Post(s)
    2016 Post(s)
    Mark, did you get the email?
  3. Re: Help A3 Unable to select Reverse Gear
    Thanks Crasher,
    Absolute diamond, gives me enough to plough through.
    Still hard to believe having trouble like this with only 50k on clock
    Mark
  4. Re: Help A3 Unable to select Reverse Gear
    Just to close this thread off.
    End result gearbox out found the 1st to 2nd selector fork has a plate RIVETED on to the fork which i believes is also part of reverse pick up? THE RIVET SHEARED, what a cheap and nasty way to secure it.
    I am lead to believe this is unusual for the six speed box to do this. Just my luck!!.
    While box out changed clutch assembly and DM Flywheel more a case of precaution and prudency.
  5. Re: Help A3 Unable to select Reverse Gear
    Jul 2009
    London
    Damn, my A3 just developed identical symptoms... no reverse then after a bunch of gear selections it came back... but now i've lost 1st and 2nd ever since!
    Avitmark, this sounds like a big job. Was it expensive?
  6. Re: Help A3 Unable to select Reverse Gear
    sorry to hear that, hope it is not,
    cost £1150 for gearbox rebuild and £650 for new clutch and dm wheel changed as part of good practice.
    the gearbox rebuild was done by Gravesham Transmissions who come well recommened
  7. Re: Help A3 Unable to select Reverse Gear
    #17
    Jul 2009
    London
    Gulp.
    I feared something like that. Thanks for getting back to me and for the recomendation but Gravesham is a bit far. Besides i have a local guy who is quite good (if not a bit pricey)
  1. Aircon stops when select fan speed 3/4
    By aedmunds in forum Touran - Sharan - Caravelle
    Last Post: 24-11-2008, 12:25 AM
  2. Gear Select Problem - 96 Passat - PLEASE HELP !!!
    By rjpaterson in forum Early Passat Forum - Pre 97
    Last Post: 28-01-2008, 08:32 PM
  3. Reverse gear problem
    By kenharkin in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 05-11-2007, 05:51 PM
  4. reverse gear trouble. v reg a3 1.6
    By aswinsco in forum Audi A3 - Archive Topics
    Last Post: 17-10-2007, 08:55 PM
  5. Sticking reverse gear!
    By omar_K in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 05-08-2007, 12:32 PM
