Thread: new faults on vag-com help please
  1. new faults on vag-com help please
    Dec 2007
    right getting there with car and these 2 new codes have popped up, any help on what they are and a cure as i believe this is whats making it go into limp mode now
    Control Module Part Number: 028 906 021 GT
    Component and/or Version: 1,9l R4 EDC G40SG 1906
    Software Coding: 00002
    Work Shop Code: WSC 00020
    2 Faults Found:
    65535 - Internal Control Module Memory Error
    35-10 - - - Intermittent
    00575 - Intake Manifold Pressure
    17-00 - Control Difference
  2. Re: new faults on vag-com help please
    If you google for "vw dtc 65535" one of the first results will take you to:
    http://www.ross-tech.com/vag-com/vw_issues.html which explains that VAG-COM runs into problems when accessing some types of airbag modules. A bug in the software, and maybe nothing wrong with your vehicle.
    If you google for "vw dtc 00575" it offers lots of ideas, including http://forums.tdiclub.com/showthread.php?p=714028 which suggests leaking vacuum pipes around the N75 / ECM area.
    Hope this helps. OD
  1. Eos faults
    By hitachizx in forum Eos
    Last Post: 11-01-2008, 11:49 PM
  2. more vag com faults
    By Dozz in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 12-07-2007, 06:15 PM
  3. faults
    By lee cummins in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 31-12-2006, 02:28 AM
  4. A3 1.8T - faults to look for
    By Graham in forum Audi A3 - Archive Topics
    Last Post: 01-08-2006, 11:12 PM
  5. VAG-COM Faults
    By anoak in forum Passat - Archive Topics
    Last Post: 14-07-2006, 09:25 PM
