Thread: 1994 2l Petrol Passat
  1. 1994 2l Petrol Passat - advice needed
    I have just got hold of a rather battered 2l Petrol Passat (1994)
    Does any one know what the oil operating temperature should be?
    Also, does any one know how to find out which engine it has? - it is a 2E but I am interested to know if it is a 16 valve or whatever
    -Derek
  2. Re: 1994 2l Petrol Passat
    Dec 2007
    the 2E is an 8valve. Mine is a '95 with 220k on the clock. Runs on lpg so had to get the valve seats replaced at 200k. while at it did big end shells and rings although neither were clapped out. It is a torquey engine which it is pointless to thrash, very un-sporty characteristics.
    oil temp is 80 - 85 C this time of year , but I have seen 105C when towing during summer.
  3. Re: 1994 2l Petrol Passat
    Cheers for that lpg boy.
    You reckon this one's good for towing then? - I have a 10' x 5' twin axle wooden trailer - very heavy which tends to rip the bowells out of older cars.
  4. Re: 1994 2l Petrol Passat
    Dec 2007
    my estate has done a lot of towing trailers, not caravans, it is more stable than my B5 estate in the same conditions. It only churns out 110 or 115 h.p. so with getting on for a ton behind means a lot of reading the road as although it will hold speed on hills , if you loose the speed at the start it will not like 5th gear.
    The smaller half ton un-braked trailer isnt a problem unless it has 12c.w.t. in and you want to stop in a hurry!
  1. 1994 Passat 2.0 16v - Lack of power
    By oldboy in forum Early Passat Forum - Pre 97
    Last Post: 12-12-2007, 07:02 PM
  2. passat 1.8 20v apt petrol still ill
    By toga in forum Passat - B5 Forum - 1997 -2005
    Last Post: 03-11-2007, 12:04 AM
  3. Stalling 1994 1.8 petrol
    By copthis1 in forum Golf MK3 - 1993 - 1999
    Last Post: 04-10-2007, 11:26 AM
  4. passat estate 1.9 td 1994 correct tyre size
    By swonny2 in forum Passat - Archive Topics
    Last Post: 04-06-2007, 09:06 AM
  5. 1994 Passat 1.9 TDI - Gear Selection Problem
    By paularcher in forum Passat - Archive Topics
    Last Post: 11-02-2007, 12:24 PM
