Thread: 1999 A6 door panel removal.
  1. 1999 A6 door panel removal.
    Anybody know of a decent online guide to doing this?
    My windows are sticky and Id like to try some silicone lube in the tracks.
  2. Re: 1999 A6 door panel removal.
    http://www.piglet-net.net/tech/cars/a3-window.html
    This one refers to an A3 but I used it when sorting my 99 A6 window issues and it was close enough.
    Note, on my A6 door card there were only two screws at the top like the A3. There were no other screws to remove around the door pull. The card lifts up and then out.
    Oh and absolutely make sure that if you have to remove window frame you mark the wedges and bolt locations. Its a complete PITA if you forget.
    Hope that helps
  3. Re: 1999 A6 door panel removal.
    cheers
    that should save a bit of cursing and breaking things
  1. Knocking in side door/ door panel removal
    By AudiwantisanS3 in forum Audi A3 - Archive Topics
    Last Post: 04-03-2008, 06:06 PM
  2. Removal Of Door Panel
    By Tazdevil1977 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 15-11-2007, 09:09 PM
  3. S4 front door panel removal
    By Lovnangel1 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 14-07-2007, 07:33 PM
  4. Door panel removal - help??
    By DeeVee in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 24-07-2006, 03:45 PM
