Thread: 02 Plate A6 2.5TDI Cambelt - need quality independent Cheshire / Manchester / Stoke
  1. Unhappy 02 Plate A6 2.5TDI Cambelt - need quality independent Cheshire / Manchester / Stoke
    Mar 2007
    Hi folks
    I've only just recovered enough from the quote from Crewe Audi to replace my cambelt - £1000 !!!!!!!
    I know it requires a variety of other bits and bobs like the water pump etc to be replaced but jeez, that takes the biscuit
    I travel about a fair bit, based in Crewe but working in Manchester, Warrington, Liverpool, Preston, even over to Yorkshire occasionally so a good deal would be OK even with the inconvenience of travelling a bit of a distance.
    I am after a recommended, quality specialist that can offer a decent warranty on the work as well as being cheap (don't want much then!)
    Can you help
    Keeping my fingers crossed
    Neil
  2. Re: 02 Plate A6 2.5TDI Cambelt - need quality independent Cheshire / Manchester / Stoke
    Quote Originally Posted by Neil62 View Post
    Hi folks
    Can you help
    Neil
    As chance would have it, I've just today picked up my '52 plate A6 2.5TDI from its cambelt change. I got it done at Money-Save Service Centre in Altrincham (www.money-save.co.uk), a small independent (with a good reputation locally) that I used to use years ago before I got the Audi. Now it's over 5 years old I felt I could no longer justify paying main-agent prices, so went back to them. I paid £840 all in for the cam-belt kit change, both accessory drive belts & rollers, water pump and, in my case, replacement of the aircon condenser radiator fan which was starting to wear out its bearings. Having costed this up at Macclesfield Audi, I reckon I've saved over £450. Money-Save were very thorough, checked with Audi what they recommended should be done while the front was off, and used all genuine Audi parts at my request; even showed me all the old bits when I went to pick it up. So far, so good -- all seems fine.
  3. Re: 02 Plate A6 2.5TDI Cambelt - need quality independent Cheshire / Manchester / Stoke
    london/ UK
    if you came to London, i would do you the cambelt for £350-370 including the water pump. You get a Contitech cambelt kit(belt,tensioner and relay roller), fuel pump belt + tensioner, water pump with metal impeller, and a fresh coolant refill. It takes about 4 hours and about £270-280 is materials. I dont make much money and i allways reset all fault codes and make shure everything is ok, especially timing ! Regards, Chris-07841206564 !
  4. Re: 02 Plate A6 2.5TDI Cambelt - need quality independent Cheshire / Manchester / Stoke
    Central Audi & VW - Ellesmere Port
    E B Jones Audi a& VW - Liverpool
  5. Re: 02 Plate A6 2.5TDI Cambelt - need quality independent Cheshire / Manchester / Stoke
    Mar 2007
    Thanks everyone. Stafford Audi will do it for £525 inc VAT which seems pretty good for a main dealer (includes all the belts & water pump, etc), plus they will lend me a car for the day
    Thanks for the offer Chris, but London is a bit of a stretch even for someone as tight-fisted as me.
    Neil
  1. Cambelt Plate
    By chegers in forum Golf MK2 - 1984 - 1992
    Last Post: 15-12-2007, 08:34 PM
  2. Cam belt change need a independent audi cheshire can anybody recommend one?
    By dragontest in forum Reviews & Recommendations of Dealers & Independant Garages
    Last Post: 14-12-2007, 02:04 PM
  3. Stoke Audi Cambelt for VW/audi£250!!
    By m4xmw in forum Reviews & Recommendations of Dealers & Independant Garages
    Last Post: 23-07-2007, 03:00 PM
  4. LT 35 - 52 plate - 2.5tdi turbo not working!
    By JOAKES24 in forum The Commercial Range
    Last Post: 03-05-2007, 04:01 PM
  5. 02 Plate TDI 130 - Cambelt
    By Streetera in forum Passat - Archive Topics
    Last Post: 08-01-2007, 11:29 PM
