I have a water leak problem that i have been trying to find for ages and seem to have found out where it is coming in from now.
The water collects behind and then goes infront of the driver seat and becomes a huge puddle if there is heavy rain i ave seen things about the seal in the door itself maybe broke or a seal for the air inlet and stuff on other posts...
But because its a convertable it is different i have found that just where the window closes against the seal on the car it is not properly touching like the whole seal around the door frame needs replacing...
Is this easy to do and where is best place to get it from..
Its the seal thats starts (as you look at drivers door) on the top left of door, theres obviously no seal at top as its the fabric roof. then the seal goes along the bottom of door and back up to the top of the door and stops on the top of windscreen...
If this makes sence????
