Thread: A4 Oil Change
  1. Question A4 Oil Change
    Oct 2006
    Bought A4 1.9 TDI SE (late 2003 model) 6 months ago, mileage 90k, FSH. Car running well but just coming upto 100k miles so thinking about doing oil change myself. Any advice on changing filter, best oil to use, whether or not to run engine flush prior to changing oil etc....?
    Feb 2004
    Yorkshire
    46 Post(s)
    If you are doing the service yourself, please make sure you obtain the correct oil for the engine... VAG Diesels can use a number of oils, all different specifications. If you look in the "supporting companies" section, you can email Opioils for excellent advise.
    Stuart
    Stuart l VWAudi Forum
    VW Audi Forum - Founder
    Member of BMW Car Club GB
    Ways to support the website
  3. Re: A4 Oil Change
    Sep 2007
    Bookham, Surrey
    Hi guys, I know this thread was started a while ago but I'm in a very similar position to Brypenny. My '53 TDi avant is coming up to its 100k service (minor service = £300 quid at dealer). For longlife services the oil spec is VW 506 01 but this has now been superseded by VW507 (extra 3 quid/L !!). My main question though is how does one go about changing the oil? I've looked under the car and there's a whole load of plastic covering the sump. Do you need to take it all off or is it best to buy one of those devices to suck it up through the dipstick pipe?
    Actually - scrap the question, I found the answer at : http://wiki.answers.com/Q/How_do_you..._in_an_Audi_A4
    you do have to take the cover plates off.
  4. Re: A4 Oil Change
    Canada
    Quote Originally Posted by TheMatador View Post
    Don't forget a new copper washer for your sump plug, saves leaks later
    VW Tiguan 4motion 2.0T 2015 - Awesome snow churning 4x4 GTI 😉
  1. A4 Oil change
    By booker1989 in forum Audi A4 - Archive Topics
    Last Post: 28-05-2007, 09:52 AM
  2. oil change
    By pkpatom in forum Touran - Sharan - Caravelle
    Last Post: 21-05-2007, 11:40 AM
  3. Oil change A3 2.0L TDI 140
    By Geraldy212 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 29-04-2007, 04:04 PM
  4. OIL CHANGE
    By vroooOOOM in forum Passat - Archive Topics
    Last Post: 30-12-2006, 06:28 PM
