Thread: Is this a Turbo? - 04 Passat 130 1.9 TDi
Results 1 to 10 of 14
  1. Is this a Turbo? - 04 Passat 130 1.9 TDi
    Got my first ever "Turbo" yesterday (estate).
    I have never driven or been in a turbo car before.
    I've read before people describing the "Turbo Kicking In".
    So I was a bit dissapointed when I didn't experiance the kick-back on my 1.9 TDi (130bhp).
    I tried 70 in 4th gear and 80 in 5th gear - it was quick, not sluggish at all, but I did not feel any change over to tubo.
    Is this correct?
    Thank you in advance.
    Gilly
  2. Re: Is this a Turbo? - 04 Passat 130 1.9 TDi
    May 2007
    Liverpool
    At those engine speeds the turbo has already kicked in.
    1998 Audi A4 2.8 V6 quattro
  3. Re: Is this a Turbo? - 04 Passat 130 1.9 TDi
    Dec 2006
    Manchester
    The turbo should be most noticeable in lower gears....... i suggest you ask somebody familiar with VAG turbo cars to take your car for a spin, and see what they think.
    The 130 is not a "slow" car.
    Nick
    1.9 tdi PD 100 Bora
    110cc pitbike, 4 speed semi-auto
    110cc Off road buggy, 4 speed semi-auto
  4. Re: Is this a Turbo? - 04 Passat 130 1.9 TDi
    south wales
    dont forget it is a diesel car after all, there a big diffrence in petrol and diesel turbo cars
  5. Re: Is this a Turbo? - 04 Passat 130 1.9 TDi
    Sep 2007
    yorkshire
    Quote Originally Posted by minty0_10 View Post
    But not in a PD 130 motor. If you cannot feel that roar power. Something is wrong. 6 speed yes?
    2003 AUDI AVANT SPORT TDI
  6. Re: Is this a Turbo? - 04 Passat 130 1.9 TDi
    Jan 2006
    Leigh
    it's probably because the turbo kicks in at very low revs.
    Is the PD turbo variable vane? If yes then you wont feel it kick in. With a fixed vane turbo you have to wait until the turbo spools up and then wayhey!!! your away. With the variable vane it alters somehow and the tourque and power is accessable straight away, you don't have to wait for it to spool up.
    '99 B5 Passat 1.8 T 20v Sport
  7. Re: Is this a Turbo? - 04 Passat 130 1.9 TDi
    Jan 2006
    Leigh
    Correct, turbo diesel's boost differently to turbo petrols.
  8. Re: Is this a Turbo? - 04 Passat 130 1.9 TDi
    May 2007
    Liverpool
    Quote Originally Posted by Alun View Post
    It is a variable vane turbo.
  9. Re: Is this a Turbo? - 04 Passat 130 1.9 TDi
    Sep 2007
    yorkshire
    Quote Originally Posted by TeaTimeGilly View Post
    I think this user is saying it is (flat as a F@rt). wastegate or variable vane.
  10. Re: Is this a Turbo? - 04 Passat 130 1.9 TDi
    Jan 2006
    Leigh
    Is this correct?
    Yes this is correct. With it being a variable vane turbo you will have a long smooth power delivery. I'm guessing it has an overboost feature so it'll keep pulling in the higher revs, much like a petrol. This is why modern diesels are as quick if not quicker, than the petrol equivelents.
  1. what turbo will fit my car? passat
    By trailking in forum Passat - B5 Forum - 1997 -2005
    Last Post: 18-01-2008, 05:30 PM
  2. passat 1.8t turbo help !!
    By rwswll in forum Passat - B5 Forum - 1997 -2005
    Last Post: 06-01-2008, 07:10 PM
  3. P Reg Passat 20v Turbo (K04 Replacement)
    By Saint99 in forum Chat - Anything with wheels
    Last Post: 24-08-2007, 09:09 AM
  4. Passat 1.8t Turbo & other problems.
    By 98passat1.8t in forum Archive posts
    Last Post: 01-02-2007, 10:49 PM
  5. Please Help! Passat tdi turbo overboosting?
    By richb in forum Archive posts
    Last Post: 01-12-2006, 04:19 PM
