Thread: reprogramming spare key / fob
Results 1 to 10 of 15
  1. reprogramming spare key / fob
    wirral, UK
    My 2005 golf came with only 1 key when i bought it, I have now bought a second key (exact same part number as original) from ebay and had it cut to fit my locks......spent £17 so far.
    I now have 2 questions-
    1. Can I go to Skoda or Seat to have it reprogrammed to my cars immobiliser as i assume they will be cheaper than vw or must i go to vw ?
    2. What is the procedure to 'sync' the new fob to my central locking, I ask this as I understand there is a DIY method involving putting a key in ignition and pressing buttons on the remote etc but i've not seen a guide specific to the mk5 golf ?
    any help appreciated.
    Mike
  2. Re: reprogramming spare key / fob
    wirral, UK
    I kept searching the web and found this......good job I did coz no-one on this site knew the answer -
    Hi all,
    There are rumors flying that programming new remote key fobs to a Volkswagen is very easy. In order to correct any misinformation or misunderstandings related to this topic, I am writing this post to explain the details of the whole key matching process.
    Quick Overview of a Volkswagen Key
    A complete Volkswagen remote key fob consists of 2 parts: 1) the transmitter for radio remote control central locking system, and 2) main key with variable code transponder. If you lose either of these 2 parts you will not be able to start your car. But this will not happen because these 2 parts are tightly attached and it is not easy to separate them. The part numbers of these 2 parts for my Golf MK5 are shown below:
    1K0 959 753 G - The transmitter (the remote)
    1T0 837 246 INB - Main key with variable code transponder
    Main key is on the left, the transmitter is on the right. Picture is at http://www.riskin.org/vwkey/.
    Details
    So how to program a new key to your car? Firstly, you will need to make sure that you get the right remote. There are literally hundreds of frequencies for the remotes, and it has to be the exact one for the central locking controller to pick it up. You can easily verify this by checking the part number. The part number of all the remotes for Volkswagen Golf MK5 starts with HLO 1K0 959 753 and has a suffix letter at the end. The suffix represents the model and the frequency of the receiver/controller being used on your car. For example, the part number of my remote is HLO 1K0 959 753 G. The suffix G represents a specific model of the controller on my car with the frequency of 434MHz. The following is a list of part numbers of the remotes for Golf MK5 I observed so far:
    HLO 1K0 959 753 A - 434MHz for mobel PR-5D1
    HLO 1K0 959 753 B - 315MHz for model "J..": PR-5D3
    HLO 1K0 959 753 C - 315MHz for model "ROK": 5D5
    HLO 1K0 959 753 D - 315MHz
    HLO 1K0 959 753 G - 434MHz
    Please be reminded that the above part numbers may not be suitable for your car. Please check with your dealer and don't buy the wrong remote.
    Secondly, you need to find a locksmith who can cut the blade of a Volkwagen key. It shouldn't be too difficult to find one locally. Bring both of your keys (the existing and the blank key) to your locksmith and they will be able to replicate the key for you.
    Finally, you will need to programme the new key to your car. There are 2 parts to programme the remote.
    One for the doors (such that you can open/close doors and set/unset alarm using the remote)
    One for the car immobilizer (such that you can start your car)
    Part 1 is very simple. The following are the procedures:
    Place your first key into the ignition and turn to the second notch (do not start the car)
    Now close the door and place your second key into the handle lock
    Turn the key to the lock position and let it spring back to the central position.
    Hold down the Lock button on your new remote, you may hear a bleep from the car
    Now unlock the car using the key in the barrel and remove, then take your first key out of the ignition
    Close the door
    Your remote should now be coded
    Please be reminded that this procedure WILL NOT add your key to the immobilizer. Even you have completed part 1 and have the blade cut, you are still not able to start your car. This procedure will only code your key to connect to the controller so that you can open/close doors and set/unset alarm. However, this procedure can be used to re-activate an existing key that's lost its memory from a flat battery.
    Part 2 is the MOST difficult part. You will need the following to complete part 2:
    Volkswagen VAS 1551/5051/5052 or equivalent diagnostic equipment, OR
    A Windows-based computer with VAG-COM and the correct interface for your car, AND
    Secret Key Code (SKC)
    Secret Key Code (SKC) can only be obtained from an official dealership. There are 2 formats of SKC from VW. Prior to 2002, some vehicles were delivered with a scratch-off panel on a plastic tag. A 4-digit SKC was printed on that panel. Starting in 2002, dealerships implemented the WIN2 system to provide SKC's to their technicians and customers. As of 11 Mar. 2002, VW and Audi are providing 7-digit Secret Key Codes in place of the earlier 4-digit SKC's. Keys must be coded using the new 7-digit SKC (secret key code) method unless the owner still has the correct 4-digit code. 7-digital SKC is generated based on the 14-digital immobilizer ID with your 17-digit VIN. Once the 7-digit code has been generated, the 7-digit SKC, the date on which the code was generated by the dealer, along with the Workshop Code (WSC) and the Importer number of the dealer that generated the code must be entered to the VAS 1551/5051/5052 or VAG-COM in order to add new keys to the immobilizer.
    Recently, VW/Audi dealerships have switched to the new GeKo system, whereby their factory scan tools dial up the factory while connected to a car. Under this system, the technician no longer sees the SKC at all and you will need to bring your vehicle into the dealer to have immobilizer work performed. Note: GeKo connectivity requires VAS 5052 and broadband connection.
    Conclusion
    If you lose your key, you don't have much choice. Firstly, you need to get a blank new key. You can simply find one on eBay. But make sure that you get the right remote for your controller. If you still have the 4-digit SKC, then you will be able to add new key yourself using VAG-COM. Otherwise, you will need to take your car back to the dealer and have them do it for you. If you are lazy (like me), just request a new key from your dealer and they will order the key and program it to your car for you. But it will be very expensive.
    References and Acknowledgement
    Synchronise a new remote keyfobs: http://www.uk-mkivs.net/forums/451448/ShowPost.aspx
    Ross-Tech VAG-COM FAQ: http://www.ross-tech.com/vag-com/faq_4.html#skc
    Key Matching Process: http://www.steveslockshop.com/VW-hi-sec.htm
    Volkswagen Key Disassembly: http://www.riskin.org/vwkey/
    Mingfinity: he is so brave to disassemble his key and check the part number and the frequency of his remote
    golfer: for verifying the part number and the frequency of a specific remote
    Aric (uk-mkivs.net): for verifying some of the part numbers and the models of several controllers/receivers
    ETKA
    Official Volkswagen Service Manual
    I hope this helps. If you find any incorrect information in this post, please feel free to correct me. Thanks.
    5 2 0
  3. Re: reprogramming spare key / fob
    Thanks a lot, part 1 works for my MK4 as well. I was able to re-sync my fob that had flat battery.
  4. Re: reprogramming spare key / fob
    I tried the reprogram thingy on my '99' A3 but tried 2 reprogram 2 fobs (battery died on 1)... doing so made one key work but not the other... and vice virsa! does en1 know how i can make both keys work?
    Thanks...
  5. Re: reprogramming spare key / fob
    My drivers side door lock just spins can i use the passenger door lock?
  6. Re: reprogramming spare key / fob
    ChillOut Guest
    Getting the key from VW is in the region of £100-£150 from memory - that's what he meant by very expensive (that does includes reprogramming !!)
    Luckily my company paid for mine after my keys had been missing for a month - not two days after that, I found them in a pair of trousers. Never told my boss!
  7. Re: reprogramming spare key / fob
    Feb 2009
    Auztralia Mate
    [QUOTE=mikegally;120526]
    Workshop Code (WSC)
    Hey there. I have a 2003 VW Passat. lost the spare key, so i got another one from VW, got it cut by a locksmith and now i need to code it. I have VAGCOM and am just curious where i can get the SKC & the WSC numbers to access it in VAGCOM.
    N
  8. Re: reprogramming spare key / fob
    Jun 2009
    Peterborough UK
    Hi - I'm new around here and this has certainly made for some interesting reading !
    My Mk5 Golf key has this part number; HLO 1K0 959 753 - just as you list above but it has no suffix letter (A, B, C, D etc ) on the end of the code. Its an early Mk5 2004 so would it be possible that the earlier ones had no suffix ? The replacement I have sourced (ebay) has a G suffix - All other details / codes are the same but it won't work. Presumably I need to get one with out any suffix letter at all ? .... and before anyone asks - no, it hasn't been scratched off )
    Any advise would be greatly appreciated !
    Thanks,
    Chris.
  9. Re: reprogramming spare key / fob
    Sep 2009
    London
    The new mk5 models i am sure cannot be paired with new keys through door lock.....
    The only way to run the remote or even get your engine to start and stay running is through VCDS - Vagcom otherwise it is not possible.
    Recently owning Vagcom my self, i have figured out the way to pair keys and that is by searching the key pairing cluster through vagcom and deleting the old number of keys there currently was and then pairing the new keys and the old one all at the same time.
    To get the transponder working ( Key tablet that allows engine to run) is to have the Secret key code (SKC) these codes are not available no more from VW them selves and will have to be secretly read from Germany via VW dealer in the UK.
    There is something called Vag Commander that can read SKC's but is a very expensive piece of hardware.
    Any more questions? write back.
  10. Re: reprogramming spare key / fob
    West Yorkshire
    Hello all.
    I have a 2002 A4 (B6 model) and have just sorted out all the new gubbins for a 2nd key fob. I got my SKC code, and have successfully coded my new transponder through VCDS. However, I cannot get the key fob to remote open the doors etc. I have followed the guide in this post, and about 7 other slight variations i've found on the internet. Does anybody have a definite way of programming the fob?
    I have tried two new batteries in the fob, so i'm thinking it's highly unlikely that it's them.
    Any advice would be great!!!!
    EDIT: I have figured it out (with help from others). As the fob was new to the car I had to pair it through vagcom. Once done all works fine now, yay! (I thought I only had to pair the immobiliser side, not the door unlocking etc as well).
  1. reprogramming key fobs
    By archy in forum Touran - Sharan - Caravelle
    Last Post: 15-07-2010, 11:09 PM
  2. Another reprogramming keys.....
    By Baker0 in forum Audi A3 - Archive Topics
    Last Post: 04-12-2007, 05:05 PM
  3. Key reprogramming
    By 1275rob in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 08-11-2007, 08:18 PM
  4. Key reprogramming
    By Dozz in forum Passat - B5 Forum - 1997 -2005
    Last Post: 29-09-2007, 07:15 PM
  5. Re sticky above about key fob reprogramming
    By Lis in forum Chat - Anything with wheels
    Last Post: 06-07-2007, 03:39 PM
