Thread: 98 golf gti 8v hits rev limiter at 5000rpm + more!!
Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 40
  1. Re: 98 golf gti 8v hits rev limiter at 5000rpm + more!!
    #21
    Dec 2006
    Manchester
    That’s it, I am loosing the plot-that just confirms all my (and everyone else’s) suspicions, been doing this too long. Mind you, at least I don't fall for pranks involving key plippers and mobile phones!
    Will i ever live that down.....
    Even you said you tried it though
    1.9 tdi PD 100 Bora
    110cc pitbike, 4 speed semi-auto
    110cc Off road buggy, 4 speed semi-auto
  2. Re: 98 golf gti 8v hits rev limiter at 5000rpm + more!!
    #22
    108 Post(s)
    1816 Post(s)
    No I didn’t, I would never be so gullible! I was just trying to make you feel less emabarsed.
    Anyway, back to the problem in hand. Setting the distributor to the correct position means starting up your lap top/diag system and going into measuring blocks 08, so that’s 5 minuets absolute tops. Then you put the screen where you can see it from the front of the car. Release the distributor bolt and turn the dizzy a small amount either way to see what change you get. If you are going the wrong way, go the other way until you get the screen readings required. This whole process should take about fifteen minuets absolute maximum. Where do you live? Anywhere near Nottingham?
  3. Re: 98 golf gti 8v hits rev limiter at 5000rpm + more!!
    #23
    hi crasher...thanks for that advice...no i live in preston..a good way from nottingham i think if its going to take 15 mins...ill print out this forum thread, take it to vw, and see what they make of it.. thanks a lot mate for ur help n i'll keep u all posted!
    1998 MK3 Golf GTI 8v
  4. Re: 98 golf gti 8v hits rev limiter at 5000rpm + more!!
    #24
    108 Post(s)
    1816 Post(s)
    PM me your email and I will email the procedure in full.
  5. Re: 98 golf gti 8v hits rev limiter at 5000rpm + more!!
    #25
    thanks crasher....ill send it now
  6. Re: 98 golf gti 8v hits rev limiter at 5000rpm + more!!
    #26
    chesterfield
    i've just had a gearbox and clutch done in mine and my rev's dont go past 5000 wud that be the same problem ?? its doing me head in
  7. Re: 98 golf gti 8v hits rev limiter at 5000rpm + more!!
    #27
    Dec 2006
    Manchester
    take it back to the garage that did the work...
    Get them to fix it.
    Nick
    1.9 tdi PD 100 Bora
  8. Re: 98 golf gti 8v hits rev limiter at 5000rpm + more!!
    #28
    108 Post(s)
    1816 Post(s)
    Check if the plug into the hall sender on the side of the distributor is disconnected or broken, they get in the way when removing/installing the box.
  9. Re: 98 golf gti 8v hits rev limiter at 5000rpm + more!!
    #29
    chesterfield
    yeah ive booked her back in for tuesday i aint much of a machnic but ill have a look 2 see if owts outa place thanks for ur help guys
    is that garage on ur home page yours crasher ?
  10. Re: 98 golf gti 8v hits rev limiter at 5000rpm + more!!
    #30
    108 Post(s)
    1816 Post(s)
    Yep, tis me!
  1. ertatic rev limiter then engine stalls
    By James_2k in forum Polo - Derby - Lupo - Fox
    Last Post: 20-07-2007, 11:16 PM
  2. golf gti 8v rev limiter in at 5000rpm????
    By s194smith in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 04-04-2007, 09:55 PM
  3. esp warning light/rev limiter?
    By easylifeauto in forum Passat - Archive Topics
    Last Post: 17-03-2007, 09:40 AM
  4. Transporter Road Speed Limiter
    By surfyak in forum The Commercial Range
    Last Post: 09-10-2006, 10:24 PM
