Thread: Heater problems
  1. Heater problems
    Oct 2006
    New poster !!! Have just bought myself a 1992 K plate coupe, very nice car... has a heater problem though & hopefully someone can help/advise...
    The heater is blowing cold air only, the heater dial is lose about half way round, also the temp gauge doesnt really move unless stuck in traffic. Are the 2 linked & is this an easy (cheap) fix, or is it a garage (expensive job.
    Have already had to get a new dash cluster & am trying to source door trim as water getting into foot well. Other than that... all is good with car.
    Great to drive.
    mikecoupe Guest
    Sounds like you've a disconnected or damaged cable. Pop the bonnet run the engine and see if the 2 hoses going into the bulkhead are warming up (all the hoses should be getting hot). Obviously check theres water in the system!!, though a warning light and buzzer should sound if there isn't. If the hoses going into the heater matrix are getting hot then its most likely a cable prob. Easiest access is to remove the drivers side panel above the pedals - 8mm socket.
    Oct 2006
    Turns out its the gearing of the heater control panel. Yet to be resolved, have orderd replacement panel - awaiting delivery.
  4. Thumbs up
    paul20v Guest
    hi sound like you have a thermostate prob to as your car is warming in traffic and cooling down when on the move this will not help the heater and more importantly the engine will be overfuelling as the car still thinks its cold and thats not nice for the pocket or the engine
  5. Smile
    Oct 2006
    Have replaced heater control panel, was completley "mullered" behind front panel !!!
    All seems ok at present, just need to source some door seals, get a damn good steam clean on the interior then will be very happy
  6. Thumbs up
    paul20v Guest
    good luck with the door seals
    Oct 2006
    may not be the door seals
    check the 80 90 forum for water in the car options
    bert
  1. Audi A4 Heater problems
    By Pete K in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 25-04-2007, 12:49 PM
  2. Heater aux heater?
    By Dave Avant in forum Audi A4 - Archive Topics
    Last Post: 08-02-2007, 03:43 PM
  3. T Reg Golf Heater problems
    By johnm in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 13-11-2006, 11:08 AM
  4. 1996 - Golf TDi - Heater Problems
    By Octavius in forum Archive posts
    Last Post: 01-11-2006, 02:05 PM
  5. 1996 - Golf TDi - Heater Problems
    By Octavius in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 25-10-2006, 08:42 AM
