OK - I'm confused by the names of things. There are some excellent photos of a turbo like mine in this post -
https://www.vwaudiforum.co.uk/forum/s...ad.php?t=19945.
The turbine side of the 'charger is rusty steel, the compressor side is aluminium, the actuating rod is clearly visible connecting the wastegate lever on the rusty bit with what I would call the "wastegate actuator" - the yellowish cylindrical bit with two pipes going into it. So far, so good and the N75 "wastegate bypass regulator valve" should be on the other end of the pipe going nowhere in the photos.
I've had a problem with my VAGCOM today - it couldn't find the engine modules, but it did find
Control Module Part Number: 028 906 124 A / Component and/or Version: Turbo-Diesel V01 / Software Coding: 00127 / Work Shop Code: WSC 00000 1 Fault Found:
01265 - Exhaust Gas Recirculation Valve (N18) - 31-00 - Open or Short to Ground
This is confusing me because the EGR valve itself has no electrical connections, and is pneumatically operated by the black solenoid valve in my photo above, which is also connected via a "tee-piece" to the wastegate actuator with the rod coming out of it. So the ECU cannot know what the wastegate actuator is doing, only what it has been
signalled to do by the opening of a valve N18 / N75 in the vacuum circuit.
So is the N18 in my VAG-COM the same as other people's N75 - " Wastegate bypass regulator valve" ? Either I'm much thicker than I thought or someone can't write a precise manual, or both :-)
Think I'll go and stroke my cats.....
OD
PS Final thought re wastegate actuator - do both pipes go to the same side of the diaphragm? I can visualise that pipe coming from the compressor output via the banjo nut and feeding positive pressure under the diaphragm, pushing the rod into the actuator and opening the wastegate once a certain boost pressure is achieved...
