Thread: can the check brake pads message be cancelled?
  1. can the check brake pads message be cancelled?
    got the check brakes message pads are fine, can the sensors be bypassed?
  2. Re: can the check brake pads message be cancelled?
    south wales
    do you mean the lights on the dash is showing?
    if you have the pads with the wires coming from them? the wire brakes when they get low and makes the light come on.
    find the wires where they come from the pad to the harnes chop the wires off were they enter the pad and join and tape them together. bit butch but should do the job.
  3. Re: can the check brake pads message be cancelled?
    when i start the car it say check brakes then i have a yellow circle on the dash looks like (0), if joining the wires solves it then i will do it tommorrow
    cheers for that
  4. Re: can the check brake pads message be cancelled?
    south wales
    it may also be the rear pads to
  5. Re: can the check brake pads message be cancelled?
    USA
    I do not recommend disconnecting this warning. You may affect the BAs system.
    Thomas
  6. Re: can the check brake pads message be cancelled?
    south wales
    how? the wires a loop inside the pad the wears the wire brakes and the light come on. by joining the wires back together all your doing is remaking the broken ciruit. what you think happend when you fit new pads and plug them in?
  1. Golf MK4 - "Check brake pads" + Essex servicing?
    By bsdbm in forum Golf MK4 - 1999 - 2004
    Last Post: 11-10-2009, 09:31 PM
  2. Check Brake Pads Warning Light
    By collieboy in forum Golf MK4 - 1999 - 2004
    Last Post: 15-11-2007, 08:23 PM
  3. STOP! Brake Failure Message
    By SteveC in forum Passat - Archive Topics
    Last Post: 05-08-2007, 11:15 AM
  4. Check Brake Pads Warning
    By Caribbeanwind in forum Passat - Archive Topics
    Last Post: 28-04-2007, 12:59 PM
  5. Stop message -electrical/brake problem?
    By toomanycars in forum Passat - Archive Topics
    Last Post: 28-11-2006, 11:36 PM
