Thread: Power window problem
  1. Question 1996 Passat B4 TDI 1.9l Power window problem
    the Netherlands
    My 1996 B4 Passat TDI 1.9l has a power window problem. The driver side goes up but will not close completely. It makes a clicking sound and jumps at the same rate when it nears the up closed position.
    Opening the window works well. It goes down to the limit and turns off the window motor.
    I removed the regulator/motor assembly from the door and looked it over. Upon removal of the Concentric washer, I noticed that the black rubber washer/bushing for the washer was bunched up and did not fit well on one part of the washer. Could this be what is causing the problem, rather than a faulty motor or motor control unit? Or could it be that the window mechanical assembly (can't remember the specific name for it..anyway it is the part that is attached to the motor and window) is faulty?
    I found out the hard way that Brose and Siemens motors do not have interchangeable parts. I returned a Brose motor to the Breaker yard yesterday. The manual does not state which position the concentric washer has to be placed in when installing another motor. Does anyone happen to have that pearl of information?
  2. Re: 1996 Passat B4 TDI 1.9l Power window problem
    North
    Did you get this sorted? as I have a simialr problem.
    1996 Passat Tow Car - SOLD
    Nissan 200SX Race Car - SOLD
    02 Polo 6N2 TDi Eco-Wagan
  3. Smile 1996 Passat B4 TDI 1.9l Power window problem sorted out
    the Netherlands
    Quote Originally Posted by Kev@KSport View Post
    Yes..Sorted.
    I replaced the mechanical portion of the window regulator. The window regulator motor was not the problem at all. A couple of the teeth on the regulator assembly had worn... that was the source of the noise and refusal to close completely.
    I bought the window regulator at a dealership for @ €25. The window now rolls up and down without the irritating ratcheting sound. I also replaced the Outer window recess seal and the Inner window recess seal (both also dealer items and not too expensive).
    My driver's side door now operates as new...no more water or air leaks (with the accompanying sound at highway driving speed).
  4. Re: 1996 Passat B4 TDI 1.9l Power window problem sorted out
    North
  5. Re: 1996 Passat B4 TDI 1.9l Power window problem sorted out
    the Netherlands
    No worries
    BTW...the wear on the teeth was not easily visible. The teeth felt rough to the touch in a couple of places near the end of travel.
    When you remove the interior door panel after removing the Phillips screws use a jewelers screwdriver (@ 1/8" dia ) or so to push the plastic clip pins into the interior of the door and then retrieve them and then remove the clips. If you do not do it this was the black clips can easily become deformed and almost useless. There are no pictures of this in the manual. I was unable to buy new ones at the *******...so the clips that the interior cover is screwed to probably only available at the junkyard
  1. Audi Cabriolet 1994 Power Window Problems
    By atlanta8967 in forum 80 - 90
    Last Post: 05-08-2008, 09:53 AM
  2. Power Loss to Unit controlling AC and rear Window Heater
    By rodinleeds in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 10-06-2007, 11:33 AM
  3. Golf MK4 Power window problem!
    By Bonkerzbanks in forum Golf MK4 - 1999 - 2004
    Last Post: 16-12-2006, 10:20 PM
  4. Passat power window and other problems
    By Schorly in forum Archive posts
    Last Post: 03-10-2006, 01:23 PM
  5. power window probs
    By malky in forum Passat - Archive Topics
    Last Post: 16-02-2006, 10:59 AM
